Robert Bianchi
I have a slightly run LGB 2085D Mallet Loco that I inherited from my brother. He bought it in 1985 and put it in a showcase with very little run time. I just bought a new LGB 5 amp transformer and controller and wanted to run the engine. It runs fine at slow speeds, and with loads on the engine. However, if I attempt to run it at higher speeds, it shorts the transformer indeterminently. It will run for maybe 10 feet and then short. If I then run it in reverse, it will run for awhile and then short. If I then run it in forward, at a moderate speed, it will short. However, if I run it at low speed, it runs fine.
Does anyone have an idea what is causing the short or where I should start to look for the problem?
Thanks, Bob.
Thanks, Bob.
