Skates can be sorted by a little bending upwards, best removed for this task. Reversely it is not all locomotives that suffer the shorting!I will try all suggestions later.
Could the frog issue be solved by sanding them down and/or removing the skates? Sorry for the basic question!
Good point Paul.Your problem is likely to be a combination of things.
Did you also test the trailing wheels for picking up current?
Have you tested the actual point rails for current on the offending points?
Oops sorry I think Paul has a big round P like you!Paul? He left the band after meeting Linda.![]()
Ah-ha! I tend to have a big P wherever I go.![]()
Thanks. Yes to both but checking Also with the wiring diagram I don’t think the trailing wheels have any connectors to pick up current.Your problem is likely to be a combination of things.
On my two the trailing wheels have no power pickups.Yes to both? Therefore the loco will run just from putting power to the trailing wheels. Is that what you mean?
The early 2073 green one and 2071D Zillertal do. You should be able to see the carbon brushes at the top of the wheels from underneath or see the wires from the rear of the locomotive if so.
Over the frog and usually it is one of the sprung centre wheels that are on the frog and creating the tilt which lifts one of the rear wheels from contact with the rail. If I touch a screwdriver between wheel and rail at that point the loco starts to move.OK. The driver wheelbase is shorter than the movable point rails. When driving slowly does the loco stop when the drivers are all sitting on the point rails or are they over the frog?
I have two of the LGB U series, 20721 fitted with a MTS decoder and 20705 which came with the Zillertal set which was already MTS. My problem is that the 20721 runs smoothly over switches even at lowish speeds. The 20705 has to be running fast or it will stop on the switches. Before opening anything up do any other uses have a similar problem/solution? Thanks.
Good thought. Would fitting a Massoth power booster help with this, assuming there is room inside to fit one?Back to the beginning, isn't this a question of why 2 similar locos run differently on the same switch?
maybe one decoder has more "stored charge" via caps on the decoder and the other decoder resets/stops, and in reality both locos are getting an interruption in power pickup?
And one decoder handles it well enough to keep going and the other doesn't? This certainly seems possible.
They are not using the same decoder. I run DCC and I have seen the "continuing without power" "range" or "distance" vary between decoders.
