Software Tools
I don't have a recent 2071, but the earliest ones with metal trail truck wheels had an overly strong spring in the trailing truck assembly which meant that often only the front driving wheel and the trailing truck wheel made reliable contact with the track.... making the loco a long wheel-base four wheel loco in electrical pickup terms (instead of the 8 wheel pickup loco it is intended to be). For running on tangent track this wasn't a problem, but it definitely did cause troublesome performance over any special work.
I wrote up the whole discovery/fix process for the G Scale Society Journal many years ago, but once you are awaware of the problem it's not that hard to fix. Just take the loco apart to the point where you get to the trailing truck spring and shorten it.... IIRC mine is now running with about 50% of the original spring length.
