beavercreek
I recently added a live steam Climax and a wood burner 2 cylinder shay to my LS geared loco fleet.
They tested fine on rollers when I was purchasing them.
When I was testing them on my layout they seemed to have problems with the track in certain places.
I inspected the locos just in case there was anything that I had not noticed when first looking them over.
All was well visually.
I decided to run one of my other locos, a LS 2 cylinder shay (this one is an oil burner model).
It went around the track many times with no problem at all.
I took the new Climax over to one spot where it had derailed and noticed that it was rocking showing track that was out of true.
I took my older shay over to the same spot and noticed that it had enough play in the bogies (or bogie springs) to make allowance of the slight track imperfection.
Same was apparent in the one other 'tricky' place.... but the older shay did not rock as its bogies again had enough 'play' to allow for the track.
I checked the bogie springs on the two new locos and they do seem stiff and there is little to no horizontal to vertical play (pitch and yaw)
Before someone says that the track should be amended, it is fixed with glued ballast and as other locos have no problem, it is not an area that I want to muck about with if possible.
Has anyone had a similar problems with Accucraft Shay or Climax bogies (live steam or electric)?
Would 'softer' springs help..is there a source for matching size etc?
How can more bogie play be introduced?
