brianthesnail96
Ooooh right! Shiny 'merican things!
Dtsteam - 16/11/2009 11:08 PM
<p></p><p>I'm not sure that the smokebox would make a difference, but a tight seal between the burner and the flue would. My Accuraft burner is a loose fit and probably draws cold secondary air into the flue. Might be time to seal it up properly :thinking: </p>brianthesnail96 - 16/11/2009 10:28 PM Does it have a sealed- or more sealed- smokebox? Just wondering if that'd affect the air (and butane) flow, different draughting?
Dtsteam - 16/11/2009 10:48 PM
<p>Generally, holes seem to be better than slots - as suggested by Charles M above. One possible reason is simply size - if a poker burner is 10mm dia then a 1mm quarter slot will be about 8mm<sup>2</sup>. A 3mm hole on the other hand will be nearer 28mm<sup>2</sup>. The larger the hole, presumably the slower the gas air mixture, and therefore less tendency for the flame to lift. Looking at a piccy of the Milton burner the thing is peppered with holes, so must be less obstructive than the slot burner. I don't know what happens if the burner is restrictive, but my guess is that you get a less than optimal gas air mix. It could just be that the slot burner gets in the way more than the Milton burner.</p><p>Btw. If you do a Google search for 'Milton burner' this thread is the second response - fame at last Matt :applause: :applause: </p>
New Haven Neil - 23/11/2009 11:44 AM
Digress? US?![]()
I agree totally Neil, it amazes me there aren't more examples of this happening. Changing the formulation of the oil will have helped, but I can't see it entirely eliminating the issue.
Once warmed up the loco ran well, but it did seem to use a lot of water......but the boiler is small. Hard to tell really, how much difference it makes. Matt's next thermo thesis maybe, an investigation into the value of superheating in small locomotives?![]()
johnsaintjim - 23/11/2009 12:46 PM
An interesting point came up about the superheater pipe on GSM towards the end. Someone said (can't remember who) that if some water found its way into the tube (red-hot, as those of us who dare to peer down the flue of fire-breathing Accy will know), it could very quickly vaporise and this would lead to a large but brief surge in power. This could happen when the boiler was very full (but not when priming, as presumably much water would cool the tube) but also if it was quite full and the loco went over a summit or a bump in the track. This seemed a very logical explanation to me of something I had seen a few times but had never really worked out.
Any thoughts or experiences anyone?
Doug - 23/11/2009 12:10 PM
Digress? US?![]()
I concurr, the Baldwin does use alot of water.
</p><p>Interesting Doug. Is this the same guy who says if you run it you will wear out the valve gear?</p>Doug - 23/11/2009 11:55 PM One of the guys at the local 16mm Assoc group is heavily modifying a Baldwin - blow down valve on the water gauage, and i think an axel driven pump for the water - uses the side tank for water.
johnsaintjim - 24/11/2009 8:33 AM
<p></p><p>Interesting Doug. Is this the same guy who says if you run it you will wear out the valve gear?</p>Doug - 23/11/2009 11:55 PM One of the guys at the local 16mm Assoc group is heavily modifying a Baldwin - blow down valve on the water gauage, and i think an axel driven pump for the water - uses the side tank for water.
