Chris Wright
Rev-Up
Fitted battery LED coach lighting and figures in mine and printed sone decals to suit the loco pulling them.
PhilP,Les,
Worth having a look for 'self-adhesive wheel weights' on the web..
You can get these in a grey finish, and are very easy to fit. - Experiment with the strips lose first, then secure, once you have worked our how much weight you need to add.
Bachmann ones are a perfect fit if you can source them.I've seen some Zenner wheels on Amazon.
They seem to be 3mm metal axle, plastic wheel and metal tyres, and the price seems competative
Does anyone know anything about them i.e.are they a straight swap for the Newqida ones?
Thanks Dan, but the loco is first generation and has been in the loft for years, so no separate coupler.It’s simply a case of change one off the couplings, do you have the hook and loop couplers that came with Lyn?
The bachmann instructions that came with mine showed you how to do it
Coined the newer 2nd generation one
Dan
Hello, will the knuckle coupler easily fix to the bar on the newqida bogie?or you can replace the coupler of the first coachbywith an LGB or Bachmann knuckle coupler.
You might want to check out these wheels too. They may be a cheaper option than the Bachmann ones, depending on your local sources and how many you buy.
I think they are nickel plated same as the ones all Kramer sells in the USA although a bit less expensive. They are 2.85cm diameter, slightly smaller than Bachmann ones.
They are very smooth unlike wonky Bachmann sintered metal ones. Not as dark looking as in the eBay picture but darker than chrome ones.
4 Pairs 8 Axles G Scale MODEL TRAIN METAL WHEEL fit for USA TRAINS LGB Bachmann | eBay
Yeah, the Bachmann Big Hauler knuckle couplings should fit the same on the Newqida which are an LGB copy.
I used the Zenner wheels - Peter Zenner knows a lot about which lenght of his axels are suitable for which carriage, truck etc., and they are slightly cheaper for the 8 axels I bought than other manufacturers.You might want to check out these wheels too. They may be a cheaper option than the Bachmann ones, depending on your local sources and how many you buy.
tac, I can't help thinking of a certain garratt livery each time I see your MÁV coaches. More of a seaside colour than a forest colour me thinks. Now where are my sun glasses?![]()
Hmm, the video frame looks a if the green has more yellow in it than your coaches, where the green seems to have more
blue in it.
The link to the attachment goes no where, btw.
