playmofire
If you are using electric points, -bbbb, you need to be sure that they are set for the direction of travel of the train as "push through" where the points are set against the train doesn't work (or at the least is reduced).
Have you found a way to integrate them with the playmobil semaphore signals (eg. the 4394 or the 4353)?If you are using electric points, -bbbb, you need to be sure that they are set for the direction of travel of the train as "push through" where the points are set against the train doesn't work (or at the least is reduced).
Nice neat wiring job.View attachment 261007
I use toggle switches, momentary ON - OFF - ON. They are mounted in the track diagram.
The wiring is pretty simple. The wires on the left go to the momentary switches, the diodes are in the middle and the wire on the right goes to the LGB switch motor.
My wiring is all color coded (I use the standard resistor color code, ie. switch 1’s wire is brown, switch 2’s is red) to help in troubleshooting.
You can see the various colors. To get higher than the colors for 0 - 9, I change the color of the spade connector and start the sequence again.
Yes, they are capacitors, on the improved version. - Note they are a little like diodes, in that they are polarity sensitive!
Capacitors can add an extra whumpf to the juice going to the point motors in cases helping to change more than 1 point at a time. In UK we talk about ‘Capacitor Discharge Units’ . Link to just one available in UK that gives a good description of what they are.I've ordered some diodes. But what difference do the capacitors make?
John, really like the looks of this as a RC (WiFi) system, could be what I am looking for, if only somebody could develop it "ready to go".For anyone with interest, the very short video below shows an LGB switch being operated using some IOT components.
It is prototype work I have been doing in an effort to completely bypass DCC.
In the video I am using a smartphone (not sown) to send a signal via WiFi to an ESP8266 WiFi microprocessor. Software on the ESP8266 interprets the signal and in turn controls a L293D chip. The L293D passes 18V DC to the switch motor. Using the software and the capabilities of the L293D, the polarity sent to the switch can be changed to achieve the straight and diverging switching of the track.
ESP8266 - $6
L293D - $3
Power Supply - Old discarded laptop
Software - Loss of hair and risk of heart attack
LGB switch (point) motors are just that, motors. If they were not mounted inside their housing and 18V DC is supplied to them they will spin like any motor.
If you open the unit up, you will see that the motor is mounted in the housing such that it can only turn about 1/4 of a revolution (perhaps less). there is gear attached to the the motor shaft which sets in a gear rack. The 1/4 turn of the shaft causes the rack to slide back and forth depending on which way the motor is turning. The track is connected to the rack which achieves the back and forth motion to change the track.
18V for 300 milliseconds (3/10 of a second) is the default pulse when using a DCC supply. If you you are using a manual switch, you can achieve that by a quick push and release. The LGB 51750 is the unit designed to control the switch motors. They can be had for $50 on eBay.
Each unit has four momentary rocker switchers and therefor can control 4 switch motors independently. You can wire two switch motors to one rocker switch, however, the two switch motors will be simultaneously activated when the rocker switch is thrown. Keep in mind that LGB signals use the same switch motor to operate. So you could wire a signal and switch to the same rocker switch and when activated the track and signal will change together.
If you are only going to control the two switches, the LGB box would be the easiest way to do it, If you are going to end up with many switches and signals, wiring as others suggested can save some money.
The LGB 51750 uses the an AC input and then converts that to DC output (using the diodes) which is connected to the switch motor. If you do your own switch you can either replicate that or just start with DC and not do any conversion.
Little warning to originator of this thread (-bbbb.), the Motors are easily dismantled but have a specific way of going back together, get it wrong and they will not work properly. Sure you know this John.Here is another video wherein I am doing track feedback.
I use fritzing.com to work up a printed circuit board for the loco units. I have yet to submit the design for fabrication.
This may end up begin a pipe dream for me but it is a fun dream.
If I ever get things to where I want, it holds the promise of:
- Battery operated trains with no DCC
- 700+ speed steps
- Real-time changing of CV settings. (I.e I can change those on the fly while operating the trains)
- Low cost sound boxes with the ability to record your own sounds.
- Control from multiple phones, tablets, laptops simultaneously
- Automated routines with unlimited options.
- Control of all lights and accessories at a fraction of the cost.
Any ideas what's going on with it or how to fix it?
it takes slightly more force to move the one that's sticking. I think you've found the problem. now I need to figure out how to fix it.Does the switch move back and forth freely using just your finger? Do it for both units and compare.
