John Russo
Use the dry WD-40 if you're going to use it at all. WD-40 Specialist Dry Lube, 11-Ounce - Walmart.com
I think you would do better with a small oil dispenser where you can apply drops.
I would take the motor completely out of the housing and stand it vertical and try to get some oil down the shaft I suspect the shaft may have some build up on it.
You should be able to easily turn the shaft back and forth by holding the gear in your fingers.
