Ox Mountain Railway
Thanks for the info :D :D
I have a basic shed made out of 4 sheets of board (so basic) and that has warped!! So I'm looking at redesigning it. I like the plastic sign board idea (what with the elections looming I'm sure I can get my hands on one), and mine has tin cans on the roof already, they have rusted but I quite like the effect.
I have so many things on the `long finger` (Irish round-tu it) - and that includes domestic type chores - that some days I can`t think straight. However a recent `phone call, inviting me to take the trailer to the Mayo Ploughing Event on the 19th of this month, rapidly focused my mind ::)
Last year, at Ballinamuck Fair Day, I experienced electrical problems. I had to link a couple of sections to keep trains running (the layout was being filmed for Irish TV as part of the fair).
When I got home, during the next couple of days, I did some repairs (faulty switches) but knew the controls needed a revamp. The rocker switches, ex-electric scooters, were not really suitable for the increase in current loadings but had served well enough for seven years. I guess now they were suffering from some sort of seven year itch ;)
ebay was trawled for toggle switches and acquired for the upgrade. Winter intervenes, extremities of ones` digits don`t like low temps and the walk to the hayshed and then back to the workshop to pick up things I forgot also did not appeal. So a few weeks ago I pulled the trailer out and parked it out of the way on the drive.
The pictures are reasonably self explanatory (I hope).....
First, the track diagram circa 2010 .....
.... then the track as it is now. The shunt now forms a loop and the back straight has gained a shunt/siding (with two sections to hold two locos or one short train) ....
The controls are housed in the brick building .....
..... and my side of the building showing the controls as they were installed in 2008.
After stripping out the controls, I made a simple framework for my panel .....
..... new panel .......
..... with the wires tagged ....
..... mounted ready to connect up to the track feeds, etc.
As can be seen from the first diagram, there were eight sections (switch No.5 controlling sections 7,8 & 9). This had been an easy way (rather than adding directly to the box) of gaining more section feeds. Then the creation of the two (electrical) section shunt caused a further extrapolation of feeds relying on switch 5!).
So the ten sections are now controlled individually from the new panel. The bottom right switch is a changeover - from tethered control to remote (Train Engineer). The one immediately above kills all track feeds and there is a supplementary latched relay also.
The third switch in the vertical row is the polarity changer - needed with the tethered control. The latter is polarity sensitive (diode and Darlington transistor) so only the ouput can be reversed.
Some track feeds have also been rewired, after which all sections were metered to ensure that all were singing from the same (polarity) hymn sheet. Then the track was cleaned and an Aristo Centre-cab operated in both modes (remote control and tethered). Success!
I did put part of the original control back for the tethered mode because I just couldn`t fathom out all the wiring!
If I had time I should meter it all out and then the the whole ensemble might look a bit neater!
Very neat work. It is amazing how tidy wiring makes life so much easier ;)
Thanks - you're too kind. I should be OK for another few years I hope. Now I need to improve the scenery - another long finger job maybe?
Nice job, Mick, and those switches are very smart with the On and Off label. I've never seen any like that on eBay before,who did you buy them from, please?
Ah, just did a search on eBay on "toggle switches" which produced 24,375 results, but Radio World was the first in the list with the very switches!
Excellent stuff as usual Mick. A tidy board and a tidy mind and all that......
Thanks for you comments all. I did buy them off ebay but cannot remember where from! Glad you found some suppliers Gordon. Tidy mind Mike? The hard drive's full and I need a new processor ;D And Ross, I know you'll understand when I say it's all done on a wing and a prayer ;)
Posted by: Riograndad
« on: April 12, 2015, 07:19:38 PM »
  Great work as always Mick ;) ;) ;)
Thanks for that - don`t know if I deserve it. :-[
Well following another thread - Nigel`s `Stuff Gone Missing`  where I seemed to hijack the thread, I found out that my picture posting wasn`t as it should be.
I found another (unused) Microsoft program which allowed me to resize in pixels rather than byte size or physical dimensions.
So here, with usual caveat (I don`t blame my camera), the first pic of yesterdays efforts on the trailer layout.
The sawmill needed some new windows as the ones I cast in resin finally broke up after eight years thumping around our roads. So the new ones were more modern and not as tall.
The next thing I looked at was the `grass`. When I made the base boards, I painted areas green where the grass should be - and some of those areas have been flat green since 2008! So the Round-tu-it, or taking off the long finger was finally accomplished!
I sieved some sawdust, got some acrylic household paint which I watered down, then stirred in the sawdust to a thick paste. Instant green sawdust. The areas to be so dressed were treated to a liberal coating of PVA Bonding, the mixture stipple on with a paintbrush (blending the mulch with the PVA), and I now have a rough textured surface.
The trouble with proprietary scatter material is it is a water soluble dye and the trailer layout has been subject to driving rain in the past. I have used oil based paints (thinned down) and this also works.
A couple more pics to follow when I get them (correctly) re-sised!.
The remaining pictures .......
Now that the mix has dried, there are a few bald patches in the `grass` - I have some more sawdust drying on a sheet of ply ready for touching up.
Meanwhile, all batteries are charged, the trailer is ready to go early Sunday morning. All I have to is wash the car ::)
Excellent Mick.
You will have to drag it over to one of our large scale shows over here!
Thank you all for your kind comments. I cannot believe it has taken seven years to get around to doing that grass (all the rest was done very early on!). And, if nothing else, I have learned to resize photos by pixel size!
Mick,great work on your trailer layout,promotes our hobby, and anything positive in that direction can only be a good thing,a real ambassador for us all ;) ;) ;) ;) ;) ;) ;) ;) ;) ;)
Everything has been neglected railway-wise. The trailer did go out to Mayo Ploughing Championships in April and all was OK. Been busy re-roofing part of the house, finishing work on the barn and no play testing at all.
This Sunday past, I thought I`d have go and run something. No chance! Nature was taking over so had to do quite a lot of weeding and clearing. The high level line is still closed (Ivy Ledge) but, after a bit more effort this afternoon, a loco made its way around the low-level lines and branchline.
Testing my picture resizing first - here`s some pics of natures efforts. If the pics don`t appear I will have to further alter them :o
There are twin tracks beneath the weeds!
Colourfull if nothing else
A few more weeds - dandelions
... Ivy ledge - impassable at the moment!
I haven`t had chance to clean the track so I thought I`d run a battery loco. Eventually I had to choose a Bachmann R/C one - could not find the Playnobil controls >:(
On the connector line (links the inner and outer circle) ...
On very recently cleared track
Heading for Tombstone (the branch)...
Entering the loop through the hedge...
Squeezing through the Lilliums before returning to the main line. I call it Tombstone because two of our cats are buried here!
Now I have some painting to do. Drat.
Great piccies, Mick. Good to see yhe sunshine. Not nice down here in the SW today.. :(
Rik
Cheers Rik. More weeding done and Ivy Ledge clipped and now passable - or will be when I repair two sections of trestle!
