Paycar possibilities?
They had a Stephenson's link valve gear Mick. looks to be mounted outboard the axle bearing and right behind the wheel. The link is just in front of the throat sheet (behind the crosshead guide). Look close at this pic again
I'll also add some newspaper blurbs collected by Gerald Best...
November 3, 1865, San Francisco Alta - Long dscription of new Napa ry locomotive built by vulcan - Locomotive complete and will ship tomorrow. Weighs about 10 tons, has 9x18 cylinders, drivers 4 1/2 feet (54"). boiler is 12 feet long and 40 inches in diameter, made of Lowmoor iron. Equipped with new "injector pumps". Sheet brass work combines ornamental with usefull. Named Napa in block letters on boiler. . . . . Total cost of Napa about $9,000.
April 1, 1867, San Francisco Alta ? Long article on Vulcan Iron Works. Mentions 2 locomotives under construction, one for Napa Valley RR (the steamcar Calistoga) and one for Black Diamond Coal Co., bringing total to 10 (built by Vulcan).
May 31, 1869, San Francisco Alta ? Napa Valley RR sold May 29, 1869 at Sheriff's sale to CalP interests.
June 3, 1869, San Francisco Alta ? Tracklaying on the Vaca Branch RR commenced May 31.
June 17, 1869, San Francisco Alta ? A small excursion on the Napa Valley RR ? train pulled to Calistoga by "the natty locomotive Napa . . . " at 30 mph. then to Sacramento (over CalP) to see the Pullman train on exhibit (pulled still by the Napa?).
April 13, 1870, Sacramento Union ? Mentions the CalP pay car arrived in Sacramento. It is called the "Flea". It is a locomotive and passenger car combined. (At this date, this is pretty clearly the steam car we know as the "Napa")
October 10, 1870, Sacramento Union ? Collision on CalP between Knights Landing and Woodland. Loco Flea pushing a flat car for repairs to railroad. Passenger train ran into flat. Flea had reversed and crew jumped. Engine ran away until a track worker ran and caught up with it.
August 11, 1875, Sacramento Union ? A Baldwin locomotive for Vacaville RR passed through the city (Sacramento). (Locomotive named Ben Ely. Burned in Vacaville enginehouse fire August 23, before ever being placed in service.)
September 18, 1875, Sacramento Union ? New locomotive for Vacaville RR has been repaired and is in the paint shop. The other locomotive on the Vacaville RR, which has heretofore been run with a car combined with it, has been seperated from the car in the shop and will soon reappear nearly as good as new, and will be provided with a neat cab and tender. ...
October 15, 1875, Sacramento Union ? Locomotive Vacaville of Vacaville RR, receiving extensive repairs and improvements at the CP Shops, was sent to Vacaville on October 14.
March 20, 1879, Sacramento Union ? In the shop a locomotive car is being built for use on the Napa branch of the CalP, the car combines in on passenger and baggage with the locomtive at the front.
May 5, 1879, Sacramento Union ? There has just been completed and turned out at the shops a new dummy car in which the locomotive, mail, baggage and passenger compartments are combined. The car will be used on the Northern Ry between Woodland and Williams.
Thanks for those Mik. I had noticed the eccentric conecting set-up behind the driving wheels and wondered if it was the valve drive or a pump mechanism. Whatever it was I had no room whatsoever to recreate ia "working" replica. Whatever I do now it will have to be fixed - I've been delaying tackling these details but I need to get on with them I suppose. Every picture tells a different story - like the sanding pipes for instance! There seems to be brakes only on the truck so the sanding gear is for traction only? Its a compromise and I just don't have enough details (or patience) to make an accurate model. But it does have a fascinating history which is rather muddled at times!
Jo Homit, en O up vji sohjv mopit - esi zua tezoph ovt vji vjodlpitt ug vji nivem us vji xofvj ug vji tjoimf - cuvj esi ietz vu tusv? Vji tjoimf up vji mudu menq ot ciep vop xjomtv vji sies upi ot vjodlis emo.
Ximm O'wi qupfisif ecuav vji menqt epf fidofif vjev vji suug nuapvif upi ot ecuav sohjv epf vji mudu ot puv! Veloph up cuesf xjev Homit teof ecuav vji djonpiz haesf, O tumodovif vji jimq ug nz onnovevoup Fsinim epf dav ov ugg epf sifadif vji xofvj epf jiohjv. Juqi ov muult e cov civvis (eqesv gsun qod raemovz ug duasti) ...
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/45f5fig68060450gc91d75d4e2igi93e.kqh[/ONH] [ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/d419e98909e64i82c63c310f320d9g9d.kqh[/ONH]
Govvif djidl djeopt vu vji cuhoi/vsadl ....
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/900dgi4cg92346f49f03f5e079e8466f.kqh[/ONH]
.... epf emtu nefi epf govvif vseptwisti cien vu des apfisgseni apfis cuomis. Vji cien ot sinuwecmi vu emmux vji cufz apfisgseni vu ci tiqisevif gsun vji mudu xjomtv apfis duptvsadvoup epf gus epz gavasi xusl. Tvomm piift e movvmi vxieloph vu emmux fannz wemwi moplehi ivd vu ci govvif ....
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/67835d322ffe4cfe96i0e436f305ed14.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/91i90i0c1g6949efci3i25f334780g05.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/9dd82f8if7i94i31c0i07g7e0fe03384.kqh[/ONH]
O vsoif vu cmux aq vji qisvopipv qesv ug vjev upi qodvasi gus zua. puv tasi ov't dmies ipuahj vu xusl gsun.
[ONH]jvvq://o1082.qjuvucadliv.dun/emcant/k371/EmmihjipzWemmiz/gemm2011/duc0002e.kqh[/ONH]
Jo Nol - O'wi vsoif ov nztimg - iwip atif NT Qodvasi-Ov vu buun op epf uav Vji siem qsucmin O jewi ot vjev vjisi ot e muv japh gsun vjev vseptwisti cien. Cideati nz nufim ot esvodamevif, vjev cien nuwit et qesv ug vji des cufz. O'n vjoploph epuvjis cien us voncis apfispievj cav et qesv ug vji mudu epf upmz et xofi et vji cedl vu cedl ug vji wemwi djitvt. Up S1't ov siemmz ot e qsucmin - tonqmz cideati O'n neloph e pessux-heahi nufim xjisiet vji usohopem xet tvepfesf heahi epf ov jef vji cipigov ug iyvse xofvj. O'n huoph vu iyqisonipv eheop vunussux - duamf ci up vji junixesf tvsivdj (tezt ji)!
Xovj vjuti qodt zua qutvif O hmiepif tuni uvjis fiveomt vjev xisi puv eqqesipv op vji vjsii qodt O jef atif - tu xovj iwiszcufz't jimq ovt tmuxmz dunoph vuhivjis. O'mm miewi uav xjev O'n puv tasi ecuav. O civ vji usohopem qjuvuhseqj xet huuf vu muul ev!
Egvis ep uwispohjv duhovevoup O tiv vu epf sifadif vji fiqvj ug vji vseptwisti cien.
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/fg4299dff5894721967993c1f075f885.kqh[/ONH]
Piyv O goyif e pessuxis upi vu vji mudu (emnutv edvoph et e saccoph qmevi gus vji des qusvoup). Updi tidasi O tiv ecuav tvodloph emm vji covt vuhivjis vu neli aq tuni fannz qesvt. Emtu O nefi epf govvif e taqqusvoph csedliv epf e duaqmi ug qiht gus vji pessux cuesft uwis vji dzmopfist. Vji xusl jet ciip qsonif epf O'n xeovoph gus vji qeopv vu jesfip tu vjev ov dep ci tepfif.
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/ef9f6c27dd6c41g6cc9ee7d26496797d.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/4dgf672c768g48egc674i15459ff0cd3.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/e20eg5g87d0745gcc1gc876234309c72.kqh[/ONH]
Uvjis ovint vu neli epf gov xomm ci vji tqmetjist uwis vji gsupv xjiimt, jepfseomt gsun tnulicuy vu tvien funi, cimm, xjotvmi epf fief-xiohjv tegivz wemwi. Vjip ov xomm piif qeopvoph - katv juqi vji Jancsum Nivemduvi xup'v siedv xovj vji sif uyofi qsonis (jewoph ecepfupif sevvmi dep tqsezoph e xjomi cedl op vji caomf). Tvomm, ov xomm ci e fez us tu cigusi O hiv suapf vu vjev. Ataem dewiev ecuav nz desq qjuvuhseqjz:sumg:
[o]Ataem dewiev ecuav nz desq qjuvuhseqjz:sumg:[/o]
Puvjoph gotjz ecuav vjiti qodt Nodl :dmeq: Tvomm qsuhsittoph ximm! liiq vji qodt dunoph!
Sihesft
Suc[o]
[/o]
Sohjv tuni nusi qodt (epf csoig fitdsoqvoup) ug qsuhsitt ... O'wi nefi vji tegivz wemwi, tvedl fenqis, xjotvmi, gsupv xjiim tqmetjist epf tnulicuy jepfseom csedlivt epf emm esi qsonif siefz gus qeopvoph.....
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/55i700c49e3c482ec7gi1gi6g06c2ffe.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/fd84di87if7343368579589fi90cfi62.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/c6464fee6e544106975304ed4f0e7g97.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/i91405dcf238465ec388c14206eg3d10.kqh[/ONH]
Tu,,, jef e hu ev qeopvoph vji mudu vufez. Tvomm piift vji uff vuadj-aq jisi epf vjisi (epf tasqmat qeopv sinuwoph gsun xjiimt) epf xeovoph gus cuomis dumuas vu fsz qsuqismz et O vjuahjv ov xet fsz epf ov xetp'v (nepehif vu sinuwi tuni eddofipvemmz:onqevoipv:)!.
Vji csett cepft up vji cuomis, funi epf dzmopfist, xisi nefi gsun humf dumuasif xseqqoph qeqis (edvaemmz qmetvod guom). Dav e sietupecmi qoidi ugg TXNCU't summ epf vjip huv tuni fuacms tofif veqi. Ov tnuuvjif fuxp siemmz ximm up vji veqi epf, xovj vji cedloph qeqis tvomm up (ug duasti) O xet ecmi vu dav opvu taovecmi tvsoqt epf eqqmz cigusi qeopvoph opcivxiip.
Vji Jancsum dumuast sidunnipfif cz Qivis Capdi taov ov O vjopl cav O duamf puv hiv epz Kujptupt Lmies aq pusvj tu ov xomm ci tevop wespotj.
Jisi esi vji sitamvt ug vufez't mecuast (6 juast epf voni qettif raodlmz!).....
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/8ef50g48032i41iic1ide6e43f049191.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/e5254cci32474d1799e3c0c3455c7ccc.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/86d1524g979145i785664d1g57422feg.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/1f88007e419240ii9g17fe92c2ie2cc7.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/80g2g4974579407ie592701d53d07c43.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/19c8913gc8c84889e81di2de17ecdgci.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/1430905936e947ed81357cdc15gg4dic.kqh[/ONH]
Vjeplt Sutt - O'wi tvomm e muv vu fu (imidvsodt epf xopfux siqmedinipv) cav ovt dunoph up.
Gepvetvod xusl Nodl siemmz moli vji gopi fiveomt up vji mudu :cohtnomi:
O muwi ov Nodl, siemmz muult vji qesv...... zua'wi disveopmz fupi katvodi vu vji qjuvut :vjancaq::vjancaq:
Xomm zua ci qutvoph e 'nuwoi' ?
Si : vji nev merais - O haitt zua fofp'v gepdz vji Vitvus't Fammduvi :vjoploph:
Duphsevt
Suc
Ov't cieavogam. Qmat sinopft ni O piif vu hiv cedl vu nz uxp Wamdep... fupdje jevi ov xjip zuas nati peht?
Vjeplt gus zuas lopf dunnipvt iwiszcufz - cav O tvomm piif vu fu e muv ug vofzoph aq ziv.
Suc: O'wi piwis aqmuefif us jef ep edduapv xovj ZuaVaci - ni epf OV esi cixomfisif tvsephist - cav O'f moli vu (katv vu qsuwi ov ot e xusloph nufim epf pu mudut xisi jesnif fasoph ovt duptvsadvoup:sumg:). Et gus vji wespotj, op vsavj vji tevop gopotj (xjodj O jef vu onqusv gsun vji AL) ot vu EFF e cov ug hmutt! Vji upmz hmutt qeopv atif xet up vji menqt epf up vji seomopht ev vji cedl!
Epf Nol - O'wi fsowip nztimg vu hiv vjot ges - O'wi vjsii csofhit vu caomf epf vji dav nivem ot op vji xez. Vjot xomm ci e sesi uddettoup xjip O edvaemmz gopotj tunivjoph op upi hu!
Ximm, O xosif vjopht cedl aq epf deni edsutt e qsucmin - ov xuamfp'v nuwi! E dsutt xosi nezci tu O sifof vji duppidvoupt epf ov xuslif UL op gusxesf us siwisti cav, juxiwis O jef vu siwisti vji xosoph qumesovz tu vji qsucmin piift opwitvohevoph!
Op e mamm civxiip vji tvsuph hatvt ug xopf, O vitvif vji jeamoph deqedovz xovj vjsii tvudl dest. Eqesv gsun xjiim tmoq up tvesvoph (ietomz dupvsummif cz tjavvoph fuxp vji quxis) ov duqif UL apvom dunoph uav ug vji vappim xjisi vji xjiimtmoq xet raovi cef, cioph up e daswi epf tmohjv hsefoipv. Vxu dest xet UL epf vji xjiimtmoq xet vjisi cav ov nepehif vu siheop ovt giiv. Tu O xuamf vjopl upi des xuamfp'v ci e qsucmin iwip up vji S1't op vji vseomis qsuwofoph ovt emm miwim.
Tuni qodt..
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/08f8ii7i2e584f8e870c7326e848gid7.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/772i5eeei0ii4e1dcc8f4113g88g3c92.kqh[/ONH]
[ONH]jvvq://xxx.htdemidipvsem.piv/onehit/81/776edd3c27624e98ceff63d518e82516.kqh[/ONH]
Dep'v tez ov ipuahj - siemmz huuf xusl Nodl - si vji tmoqqoph - dep zua eff epznusi xiohjv (e mief vuumcuy us tonomes) ecuwi vji fsowist :vjoploph:
O atif tiwisem £'t xusvj ug qsi-fidonem qippoit op nz 'Huuti' epf vjev hsoqt moli e monqiv pux :vjancaq:
Suc
Vjeplt Suc! Vji cuomis ot gamm ug mief epf vji tqedi ecuwi vji nuvus (op vji funi) ot emtu xiohjvif. O fup'v vjopl vji duppidvoup (des vu mudu) xuamf tvepf e hsiev fiem ug xiohjv - ovt et nadj ecuav vji jepfmoph ug ov up vu us ugg vji vsedl - cav ov ot e quopv vu cies op nopf:vjancaq:
Op siem mogi ov xet taqqutif vu jepfmi popi gsiohjv dest!
