What are you using as the base for this? If Conctete G4 may be an option as it is used to seal Concrete in Ponds so that Fish do not get any Lime in the Water. Not an issue for you. It is available in Clear, but can go yellowish over time.I want to build make a short bit of water to fit under a bridge. The idea is to use one of the resins for this, anyone got any experience or suggestions with regard to what will live outside without discoloration?
Old fridges shouldn't be too hard to find, generally found lurking in ditches or lay-bysWhat are you using as the base for this? If Conctete G4 may be an option as it is used to seal Concrete in Ponds so that Fish do not get any Lime in the Water. Not an issue for you. It is available in Clear, but can go yellowish over time.
If you are looking for a very short section that is a Flat Surface have you considered Toughened Glass? Old Fridge Shelves are a good source for this if you can find one.
I might be able to help you with some old fridge shelves?If you are looking for a very short section that is a Flat Surface have you considered Toughened Glass? Old Fridge Shelves are a good source for this if you can find one.
Nice idea Gizzy, how you going to get them to Middlesborough?I might be able to help you with some old fridge shelves?
I will check later....
I'm sure Graham and I can resolve this, should he be interested?Nice idea Gizzy, how you going to get them to Middlesborough?
Oh Helicopter drop?I'm sure Graham and I can resolve this, should he be interested?
Watch this space JD....
Cracking ideaToughened glass?
it'll be fine mate....
The word 'drop' is worryingOh Helicopter drop?
Not if it's preceded by the word "lemon" or even "pear"The word 'drop' is worrying![]()
I respectfully suggest that if the 'drop' goes pear shaped, or turns into a lemon, someone cocked up, so a typical SNAFUNot if it's preceded by the word "lemon" or even "pear"
Yep was this thinking of the scenic stuff but was not sure if it was waterproof. Perspex from experience will degrade. The reason for thinking the liquid route was to incorporate some rocks etc. I think I will investigate the casting resins and see if I can find one that could be suitable.Not sure what you mean by the diorama stuff,would it be the Woodland Scenics water products for example?If so I have used inside but in all honesty don`t think it could be used outside,sorry If i have wrong end of the stick,I have used layers of yacht varnish in the past too.Might be a stupid idea but,,,,,,,,,,perspex sheet?
