Polarblair
![United-Kingdom Country flag](https://gscalecentral.net/misc/flags/shiny/32/United-Kingdom.png)
Me too, I want this turntable too.
I was wondering if this version is big enough for loco 4010 or 4052 ?
It is impressive job anyway
We could think this turntable is coming from Playmobil shop, which is great
The 4052 is 54cms over the couplings.We are going to find out as I found a cheap 4010 on fleabay and it's due any day now.
Did they make an RC version of the 4052?
I have the original brass track version but I'm pretty sure it's too long.
I'm going to remodel the turntable with lessons learned from this prototype and to make it more modular to let people have blank plates instead of track all round to better suit their layouts.
Brilliant! I can imagine a few folks would be interested in thatAfter reading about a lot of issues people have with wood filaments I was a bit worried. Unrelated while printing the last of the copper frames my machine also broke down 3 times resulting in a complete teardown of the hot end.
She no happy.
Had to replace the nozzle and both the sharbite type fittings that hold the Bowden tube in as the tube was being ejected mid print. The printer doesn't realise anything is wrong so just keeps feeding filament. Thankfully this spaghetti mess could just be rewound back onto the spool. Particularly proud of myself managing to do the tube and fittings one handed while shoogling my youngest
Took the opportunity to upgrade with a couple of light strips and an improved part cooling duct.
I don't mean to put people off the ender 5 plus. It's the first failure in years of operation with zero maintenance on my part. I should probably not have neglected it and given the hotend a service long before now. Lesson learned.
Some fine tuning was required on the frames to let them just drop in without any sanding.
Back to the wood filament. Initially I ran into one failed print that was my fault. Feed rate was much too high. Once this was reduced it's spat out the 3 duckboards without issue.
Print settings were 210C, 120% flow, 50mm/s and a bed temp of 60C.
No warping, bed separation or any other artifacts to speak of. Layers have bonded well and it snaps perfectly into place.
The boards were printed face down to the printed for a nice smooth finish. I also aligned the filament path lengthways with the boards. Tempted to not bother sanding it and leave as is.
It's come out looking very Playmobil
We did a quick function test and wee man is delighted.
The matte charcoal PLA I used is a bit old. The diagonal struts that click into the duckboards require some fettling but thats easy enough.
In summary I can wholeheartedly recommend that wood filament. See previous posts for details. The supporting joists are being printed and should be ready this evening.
You are welcome to accept the challenge.I'm positive I've seen those as an stl but would be a 5min job to recreate. It's also a good 3D printing candidate with the stresses on the part going perpendicular to the layers.
If you have an STL in mind I'm happy to do you a test print. Technically all PLA is "biodegradable" but I've seen real world tests on YouTube where people have printed plant pots and found no appreciable degradation years later. But I wouldn't use it for structural parts personally.I need to find someone who has printed in wood - infused PLA, and has a scrap print kicking about..
I know very little about the material, except it supposedly biodegrade, and might be prone to warping.. - I want to see how it takes an internal thread, and then leave it out on the patio.
Get a first-hand idea of durability.
Unfortunately Playmobil did not make an RC version of 4052.
As 4052 became rare and expensive, we have to think twice before convert it to RC.
And it is better to convert tender too , in order to keep bollard pull.
But you already have huge stuff and you take advantage of it
with this very functional layout and its many possibilities of traffic lane.![]()
Challenge acceptedYou are welcome to accept the challenge.![]()
Cheapest I've seen is an incomplete 4025 for £80 which to me feels expensive, As for the RC version, only one I've seen on ebay is £128.66 + £19.56 postage. I'm slightly out of touch but that feels like a lot. The complete 4085 set is up for sale at £685.32The old red diesel goods train still can be found , not so expensive.
( You might need only cabin, and create RC frame with 3D if you do not like the Orange version which exists in RC already )
But I understand why your 4052 will stay in the attic for the moment.
If you're talking about the 4085 RC set, I think that was quite rare. If you're wanting a track powered one as here, http://www.walts-playmobil-collection.me.uk/4025C.jpg, message me.Cheapest I've seen is an incomplete 4025 for £80 which to me feels expensive, As for the RC version, only one I've seen on ebay is £128.66 + £19.56 postage. I'm slightly out of touch but that feels like a lot. The complete 4085 set is up for sale at £685.32so not on the cards for me.
By contrast I picked up a complete 4018 set in box for £70 and just today replaced the nicad batteries with higher capacity cells.
Managed to spy another incomplete 4018 without track but with motor unit and remote for £25 which will become the base for my DIY 4025![]()
Yep, was hoping to find either a cheap 4025 I could use as a donor to convert to RC or the ready to play 4085 but as you say quite rare hence the price. Thank you for the offer but very luckily I still have my childhood 4025 set in the attic but it's too precious to me to hack apart. Short of finding a cheap fairly busted 4025 I think I'll have to go the 3D scan modelling route but that will be a fun project.If you're talking about the 4085 RC set, I think that was quite rare. If you're wanting a track powered one as here, http://www.walts-playmobil-collection.me.uk/4025C.jpg, message me.
I have had PLA test pieces (supports removed from other prints) sitting out on my layout for over well 12 months now they have endured 2 Australian summers with extreme UV levels plus a lot of rain and they show little sign of degradation.If you have an STL in mind I'm happy to do you a test print. Technically all PLA is "biodegradable" but I've seen real world tests on YouTube where people have printed plant pots and found no appreciable degradation years later. But I wouldn't use it for structural parts personally.
I think UV damage will be a much bigger issue. The Playmobil RC train sets are generally seen as indoor play and I think I would make that clear if I ever get this to a point where it's a saleable product. An easy alternative would be to offer an ASA printed version at a higher price point for those who wish to use it outside. That being said, depending on source and quality ASA filament can be up to twice as expensive as PLA.
ABS would probably be best but warping becomes an issue. I have a Bambu Lab X1 arriving tomorrow so will see how well it handles ABS.
For the moment this project has taken a backseat. Have spent the last week working long hours building a steel frame garage in some of the hottest days this year. Client just had to have a black shed too! Spent many a delightful RMR weekend getting thrashed at Barry buddon during the summer months and can honestly say the last week was tougher![]()
