Eaglecliff
I thought it was 633 Squadron...Wasn't it the Norwegians that sabotaged Hitler's heavy water used to develop nuclear weapons?
Maybe they got to it.![]()
Dehydrated water? Now THAT's a trick. You'll have to explain, please.
tac
Well-publicized scam/joke. Empty tin. Saw it featured somewhere recently... some people will believe anything, that’s why America has ordered the word .”gullible” to be removed from the Merriam-Webster dictionary.Dehydrated water? Now THAT's a trick. You'll have to explain, please.
tac
Did the extra weight on one side make you lob-sidedWhen I took part in a medical research project a couple of years ago, they filled my arm with Heavy Water. Not sure why or what happened to it.... Just thought I’d mention it.
Only briefly. Blood’s thicker than water...Did the extra weight on one side make you lob-sided![]()
tac
Ah, but this was heavy water!Only briefly. Blood’s thicker than water...
The extra weight was probably balanced out by the weight of the muscle tissue biopsies they took out of my leg.Ah, but this was heavy water!
(The object of the research involved the effects of exercise on ageing. The delightful young lady in charge got her doctorate and I got £100. Apparently there was a research programme involving a heart drug; if you let them stop your heart momentarily and then restart it with their new stuff, you got £100,000. Or your beneficiaries did).
Stuff that for a game of soldiers! - I have enough trouble getting central heating circulators to errr... circulate..
NOTE:
When did 'pumps' become 'circulators'?
AND...
Should they not be 'rectangulators'? - Knowing how most heating systems are laid out?![]()
A pump should be a positive displacement, where a circulatory, is rotary (generally) and if to much resistance is placed in the line the fluid will idle in the device.
So seeing as many are 'in' with the boiler, on the kitchen wall these days... They must be 'pumps', as they have to displace upwards to the first floor circuit as well.
Does explain why the impellor design in them is so carp though!![]()
Impellers are not designed to raise pressure, by the very nature of a system impellers will raise some pressure, however as the restriction becomes greater, you reach a point when the pressure drops and quickly goes to idle, whereas in a positive displacement pump, when the maximum pressure is reached you could get a hydraulic lock, hence safety valves and bursting disks, to prevent this, none on an impeller system.So seeing as many are 'in' with the boiler, on the kitchen wall these days... They must be 'pumps', as they have to displace upwards to the first floor circuit as well.
