Station build from scratch
Well today i cleared away my old station and made room for the new :thumbup:
New p:bigsmile:latform in place and clerance testing was put underway
Then we just had to do a little testing , would be rude not to :thumbup:
Steve said:
robsmorgan said:
WOW Steve!
Beautiful work, I hadn't come across the original post :admire:
I only take this sort of trouble with my wife's dolls house fittings.... where they are safe from the elements (apart from dust).
Congrats
Rob
p.s. Perhaps you can advise me on how to adjust my (cheap brand) bandsaw - I simply cannot cut a straight enough line to use on detailed work - always veers to one side or the other :rolleyes:
Rob
The band they come with is about 6 mm exchange it for at 10mm blade then all your cuts will be straight:thumbup:
Thanks for that tip Steve - that sounds about right (6mm) will sort out a 10mm a.s.a.p.
And those additional pics posted..... really good work...... you've set a high standard... I will have to make more effort now!
Best wishes
Rob
robsmorgan said:
Steve said:
robsmorgan said:
WOW Steve!
Congrats
Rob
Rob
Best wishes
Rob
Rob tension on the blade is also very important for keeping the blade straight if it's too tight it's worse than too loose!! and adjust the bearing under the table to just have a clearance when not cutting but the cut will push the blade onto the bearing....................and DON"T you push, let the band cut and you feed!!
OOO how rude of me, Nice station Steve.............................That D Bag looks smashing...................
Envious - it looks really great (I was looking forward to seeing the finished station ever since I first spotted your thread) - I'm not disappointed! Platforms look very effective too. Well done Steve.
Mick
minimans said:
robsmorgan said:
Steve said:
robsmorgan said:
WOW Steve!
Congrats
Rob
Rob
Best wishes
Rob
Thanks Miniman, I will try harder!
Steve - thought you might be interested in my old 0-16.5 L&B station.... the roof tiles were 'made' by threading cotton through tiny holes in the plasticard roof, the walls were also plasticard plastered with Polyfilla and sculpted before painting with acrylic art paints - had to take it in at night though:rolleyes:
Hillman Impman
Rob
looking out of the window the weather looked nice :bigsmile:
Did not last long to blooming cold
So as it was so cold i decided to have a bash at making some benches for me station
There's no end to you Steve!!
Rob
Rob
I thought that was Z man???
minimans said:
Rob
YOU ARE CORRECT SIR (thinks: not tangling with Miniman! - my .22 air rifle is NO match for his paintball gun!)
Rob
Steve said:
robsmorgan said:
WOW Steve!
Congrats
Rob
Rob
Steve....... thank you, thank you, thank you!...... I've just changed the blade as you suggested and it works PUURRRFECTLY - and to think I was all for dumping it!!
Much love
Rob
:confused::kiss:
Hope you ordered two blades Rob as mine has just broken :crying:
Funnily enough I did get two - from Axminster Tools (axminster.co.uk)
Cheers
Rob
Just spent a lovely hour with my bandsaw :love:
Thanks again Steve, the larger blade has made all the difference - a brilliant tip!!! and I was going to rename it my 'fret' saw
Regards
Rob
You have stopped fretting now then :bigsmile:
