Not perfect for the crossing.. But a little more 'to the right', with a barrow crossing at the bottom of the steps to the base of the platform ramp would not look out of place?
Didn't some of the crossings have huts for the gateman rather than a signal box?thanks, It didn't put it quite in the right place for the pic as it would squash my little plantI ran trains around for an hour with it there and you get a good view of it plus , I can if need be put it in the shed if the weather's going to be nasty as it's easy to reach in that spot, as it's the first building where 60% of it is 3D printed I have no idea how well it's going to suvive in all elements..I have no problem with a barrow crossing as it adds to the scene my worry is the level crossing at the far end where the signal man should be the one too open gates if the box is near them, don't want to add another box just because of the gates, but after watching "the railway children" last night the Porter ran down his platform a lot to open / close the crossing gates, no signal box in that station tho.
Indeed they did and a few still do. One is situated between Melton Mowbray and Oakham.Didn't some of the crossings have huts for the gateman rather than a signal box?
It probably wouldn't matter too much, apart from picture 2. The stairs wouldn't be built to go straight onto the road and the bannisters and the platform may obscure the signalman's view of the crossing as he would need to look down.
SWMBO said what's the problem, just make another box the opposite hand![]()
You'd better get started then, if SWMBO says so!Pic two would have worked if the stairs was on the opposite end of the signal box, as you say they would never build a box with the stairs straight down onto the road / footpath, SWMBO said whats the problem just make another box the opposite hand![]()
Is there ever any doubt?Decided SWMBO was correct ...
