That's marvellous, what did you use to make the tank?
Thanks, it certainly looks the businessThanks, the tank is made from PVC board, the raised frames were then glued on and the rivets are brass pins , I have 1000s of them and a pin pusher from the days I used to make wooden galleons![]()
What's the score with the signals? Are they scratchbuilt or bought?
They look good!They were modeled by me and then they are printed on a 3D printer I bought, it's not a printer that costs a silly Money![]()
Tell us more..
Which is pure PVC board, and which is printed?
Sid you say th printer was a cheep one, judging by the lookof the stairs it certainly appears to do a great job. Can you give us a pic of the beast and make please? Might be just the beast to go for for those few items that are needed amongst us. Oh then there is the need to learn 3d cad, but I keep hearing and seeing people doing things with iPhones and iPads that may just work for me if I investigate further.The base is all PVC board except the window and doors,
The stairs is all 3D printed,
The upper, all wall frames and windows and roof trusses are printed with infill boards made from PVC
The roof all framing / roof trusses are 3d printed the roof outer shell in PVC board, Roof tiles do know yet what they will be made from.
The Man was bought
Internal Lever frame, Stove and other fittings will be 3D printed as you will be able to see most of them so I suppose I should built the inside of the Signal box.
