There will be a lot going on either side of that narrow path..
What is bottom left of your plan? - Where is house / patio in relation to the railway?
I think I would move the lower station to lower left straight (and end curve) of that border?? (Think of Ffestiniog, Harbour station)..
Apart from that.. LAND-GRAB! (with approval, a result!)![]()
You have got quite a long run there. If space for return loops is a problem, remember real railways rarely have a turnaround loop, that's why they have turntables or tank engines that can run backwards. Unless you definitely want a continuous loop, you could have a more prototypical end to end layout with run-around and passing loops. It would be more interesting operationally but more "hands-on". If you wanted to sit and watch trains rather than drive them all the time there are options for automatically shuttling trains to and fro using DCC or analogue, although it's very difficult to automate the full "uncouple loco, run around to other end of train, couple up and go" without more sophisticated probably computerized automation....It takes a lot of space to turn a train round![]()
If space for return loops is a problem, remember real railways rarely have a turnaround loop....
Been having a Play on the PC costs nothing to experiment that wayleft hand end would have two curves Lower as a return loop for continuous running, outer loop to elevate up to feed the new area with a terminus type station rather than a loop as the above pic had, that way there is more room for plants and buildings. The Spur behind the Right hand side station might go, again to allow more plants to separate the station from the back line, as the area is not really big enough to do what I was going to build there. Not sure about the Lower central stop area now weather to keep it or not...funny how things look a lot different once they are in the garden rather than on a PC screen. Is the idea below of two loops and a terminus station better than the previous version for running variations ?
Indeed, the only ones I know of are Ely North Junction (Adelaide Loop),
and the one on the Harz Railway, close to Stiege....
You are of course correct Paul. It is probably used more than the Ely curve, and has regular scheduled services, so it is a 'main line' in miniature.Not full size but Dungeness on the Romney, Hythe and Dymchurch.
Paul
I rather like this, with a Terminus, Through Station and a Reverce Loop you have a great option if you would like to do Timetable Running.Been having a Play on the PC costs nothing to experiment that wayleft hand end would have two curves Lower as a return loop for continuous running, outer loop to elevate up to feed the new area with a terminus type station rather than a loop as the above pic had, that way there is more room for plants and buildings. The Spur behind the Right hand side station might go, again to allow more plants to separate the station from the back line, as the area is not really big enough to do what I was going to build there. Not sure about the Lower central stop area now weather to keep it or not...funny how things look a lot different once they are in the garden rather than on a PC screen. Is the idea below of two loops and a terminus station better than the previous version for running variations ?
