At last a Dry Saturday so time to start installing platforms , changed one set of points around to the opposite hand to remove an S bend in my tracks, Laid the tracks between the Island platform at the new centers so I have 140mm Loading gauge so trains are only around 10mm off the edge of the platform. Tracks and Island platform all screwed down to hard wood battens below the gravel and Alpin grit, so if one moves they all move together so the loading gauge won't change Two Playmobil lamps installed and wired up, I did shorten the base a bit more and the overall height a little bit, now they look about right height to a G scale model person.
Outer platform where the building sits not installed yet just laid out to make sure it fits, it needs the two half's joining together then it can be installed. Station name board benches etc. etc. still to add to the island platform..
One problem with changing the points around is my line side shed is now on the opposite side of the track to what it was designed for so I no longer see the door, window or light at night, from the garden side , unless I install the building the wrong way round in theory ? with it's window facing away from the track instead of towards the track.
Building at the moment only has the light added to it, and the points have a manual lever on them. The building removes from it's base so it will house the point motor and wiring inside the building with a rod coming through the wall to the points, water proof and hides the big point motor. Didn't add the motor yet as now I have gone DCC will need to re-think the controls for point's etc.
Now they are out will see if they weather on their own, which I assume they will do which is why I didn't weather them while painting.
