I do like that station..
Some form of anti-grav device, automatically adjustable for variations in the planet's magnetic flux and mass of the trains.... just have no idea how to support the curve bits yet.
Some form of anti-grav device, automatically adjustable for variations in the planet's magnetic flux and mass of the trains.![]()
Sonic screwdrivers don't work on woodYou mean a plank of wood then!
Looking good - ideally you want a short straight between the curves on a reverse curveMade a Bridge this week, Isambard would be proud of it ROFL..it fills the hole for now winters project to made a proper one.
Swimbo's plant seems to have moved from when I measured it..... so had a redesign decided to raise the whole area to support the track all the bits of wood and bricks will disappear when the whole area gets raised, more civil engineering
Ignore the points on the Left I ran out of curves![]()
Looking good - ideally you want a short straight between the curves on a reverse curve![]()
Yep, bodgers like me would do a bit of belly bending to ease the curves - works a treatGoing to play with the curve once the bed has been finished and filled to see it I can get a better shape also going to try to get a straighter line from the curve that leaves the bridge to where it joins into the curve around the tree...but had to join it up so I could run Train's again![]()
Even with the 150 ft of second hand flexi-track that I bought to help complete the WWNR, it was easier to belly bend the flexi rather than use the previously enjoyed rail bender![]()
