Rhinochugger
Retired Oik
Two days Building SWMBO's new Garden shed in the sunshine and I get the day it rains to work on my layoutmore work done on the land grab boarder , all the rubbish cleared , membrane laid and covered in gravel, The raised border isn't high enough so I still have to raise the tracks as they run across it so there is clearance where they cross over the existing track , not sure what is the easiest way to do that yet ? The wood and bricks is just to give me the height and show where the track will run. Decided not to build a return loop in the border but run to the very end instead and have anout and back type line as an addition to my continuous loop. (It's also heading in the right direction to join into the other end of my layout shh.. don't tell SWMBO )
Somebody wants a castle Ruin, might cheat and buy the Pola kit rather than make one, as the rain set in the image below shows what it might look like one dayFound a Garden center that has four big rocks that would build the base for the castle, concrete is not good enough I have been told...
The viaduct might be wishful thinking..
Or perhaps not, you can easily make one out of a few Celcon Blocks. They cut nicely with a Jig Saw and with a little treatment with Waterproof PVA and Stone Colour will look good.
Or perhaps not, you can easily make one out of a few Celcon Blocks. They cut nicely with a Jig Saw and with a little treatment with Waterproof PVA and Stone Colour will look good.View attachment 223819
The cracks were when I was a little overenthusiastic with Mr Lump Hammer when tamping them in place on the base. You can even scribe Brick or Stonework into the stuff with a nail. Mine is still awaiting some treatment and is as placed some 4 years ago. I made a similar one for the Ruschbahn that showed no sighs of damage after some 9 years outside.
Sound plan, they are not that expensive so worth a punt. You may even get two sections if you cut in half lengthwise.Thanks, looked on the Web last night at ways to make a viaduct and came across the Celcon block method, just not sure if my viaduct is high enough to leave 1 1/2" to 2" ? at the top of the arch to stop the blocks cracking while you cut the arch. The track is about 4" 100mm total above the ground level, might pick up a single block and cut the arch in one to see if you can see enough of the arch at my height if that makes sense![]()
1in10 looks like rack to me.
Gads, sir, you have a mean streak!I'd like to see you limbo dance under that bridge![]()
