With the previos writing: I had the guts to make something that WILL be on my garden layout, incl the knowledge that was giving on this and other forums.
I think this one is for real.
Cutting all the sleepers to there right seizes.
And cutting the slots where the alu strip must go with help of my new jigs.
pre bending and making sure everything is oke before glue
Some fine adjustments with a fine cutter.
The black fillers(3mm) are for normal locomotives, the blue fillers(4mm) are for those oversized locomotives.
This is the curve (5meter radii) that can run the really big ones, it will be a separate track/road for them.
So this was the dry fitting of the rails.
I tried some other putties in the last year...but polymax still wins. this discussion is closed!
I tried i the mean time around 25 different putties on top of the ones i tried before, but a ms polymere, beats all
There are two othere ones beside polymax, also ms polymere based, they are cheaper but also promising.
I will round them all up for one picture incl the ones that are not up to this task.
With glue i am done with experimenting, picture of all will follow.
Not bad dont you think?
4mm spacing and 5 meter radii and for normal locomotives 3mm spacing and 3 meter radii
The nmra1 standards where really happy, no bumping derail or whatever, when i extended it in the garden as experiment
With best regards Igor K
