Space permitting, there's always the option of a reversing triangle.
A discarded 'Lazy Susan' makes an excellent base for a turntable. I suggest it might be motorised using a cheap electric screwdriver and a little ingeuity
That's a great find and amazing value. It would only be big enough for 0-4-0 and maybe 0-6-0s but even so.Behold - https://www.swiftsixteen.co.uk/Turntable
Just needs a bit of fettling and colouring in.
tac
As you saw - it's a tight fit for a short and stubby loco like my Accucraft 'Earless' and therefore more suited to the 0-4-0s. I guess that anybody with anything bigger is on their own...
tac
In my pile of STUFF is a lazy Susan, of sorts, and a B&D cordless drill just waiting to be converted into a turntable. All ready have figured out the switch on the drill so it runs at a slower speed. Lock the trigger at the speed you want and then add another stop and go switch. Rewire the reverse button to a switch so you can go in reverse. I plan to use a discarded right angle drill attachment so the drill fits flat on it's side. This will further reduce the speed and increase the torque. Hope this info helps.
Thanks, it's a good suggestion, though controlling the drill motor accurately enough might be a challenge for fully automated operation.
Which is why I suggested a small electric screwdriver, perhaps with friction drive to the rim. It'll be quite slow making it more controlable.
Well it's certainly doable, may need a few ancillary parts.
Components and parts shown, tried and tested several options, by far the easiest and simplest is using a potentiometer to control the stepper motor.
Have incorporated a Hall Sensor as a means, to control stop, start, rotation etc.
Slightly more complex but achievable is using a DIY DCC Decoder, operates via the rotary dial on the Massoth Navigator.
Even more complex, but workable, is using the Massoth DCC inbuilt Automatic Drive & Switch routines.
Down to personnel preferences and very much depends on how or what is manageable or achievable.
This project is earmarked to be incorporated in a small modular "test" layout, work to commence on it starting early Autumn.
True, though given I don't have an old electric screwdriver that is surplus to requirements, and given that a stepper motor and an arduino kit to control it is less than £25, I think I'll probably stick with the arduino option.
That is all fine if you can speak the Martian dialect of Arduinese.
But that's the fun bit!!![]()
Guess that would be as in the Martian dialect of Arduinese, 01100110 01110101 01101110![]()
