Looks like it's all systems go then. Have a look at Greg's DCC link earlier for advice on how to chip it. Have fun.Like I say my main line is all aristocraft r2 so I should be okay and all my stock has hook and loop couplers so that should help as well
I take that a massoth xl decoder will be good enough for this
I have a LGB 5amp transformer, so if I would run this and my mallett together would it overload the transformer. My mallett and franks are okay running together both twin motor locos.I would tend to use an XXL. - These can be 'hungry' beasts!
I am not sure an XL would take kindly to a full-stall?
As has been stated, a 5 Amp controller would be a minimum, really. One of these, plus 'something small' would probably be OK, but don't be surprised if a 5 Amp controller shutsdown due to heat.
I use a 3.5 Amp bench supply for testing, and setup.. If the motor's are a little 'tired', I can hit the limit on this, at times. - Single engine on rollers, so little load. Imagine out on the track, with curves, and pulling stock.
Thanks for all your info Phil I'll give you some I info on my railway.It may seem 'doom and gloom', but it depends what you want from your railway?
Rule 8 - Your railway, run what you want..
If you *really* like a certain loco.. Then either build your line to a prototype to suit, or just run it anyway, and enjoy!![]()
And well said it's my railway maybe I'll buy it run it hope for the best and enjoy it.![]()
So either switching off the lights or swapping to LEDs would significantly reduce current draw
I find the GP38 bogies are very free turning.
I have posted this before but it fits this thread
Need to get a BNSF swoosh one next thenI've had my BNSF GP38-2 in war-pumpkin colours for years, after finding a photograph of the actual loco online.
