Weathering with dummies
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
Hoeksche Waard - Netherlands
So this dummy is starting with weathering! I have two practice subjects, an already two times painted postal wagon and one flat car, which at the moment is still orange (aren’t they all orange?!).
The postal van is not in use anymore, I got it when I just started with the hobby when ‘you get what you can afford’ (well, that’s how it started for me...)
The flat car is used frequently as it has the cleaning blocks underneath, but being orange it is quickly removed from the tracks after it has done it’s duty. So this one will hopefully see more use with a more fitting color.
The last couple of weeks I have seen many Youtube vidS (I hate Youtube...) about weathering. There are many techniques and some of them I think are quite interesting to try myself. As I am a complete dummy in this area, I think it might be fun to post my endeavors here for people to help me on my way and to prevent others from making the mistakes I did.
The first test today was ‘washing’. Using a dab of paint and thin it to the max and just paint your model with this watery stuff. I first tried a dark brown acryl paint (Action) with lotsa water. It didn’t apply as smoothly as I would like and using brown suggest rust and I’ve never seen rusted planks...
The enamel was a dab of Humbrol black with some ‘thinner’. This worked a bit better and the color is not ‘rust’ but just dirty. I’ll post more pics tomorrow when it has dried.
A nifty trick I saw recently is using hairspray and immediately apply chalk dust. The effect was amazing imitating dirt and rust.
Also I got pigments from Vallejo (?) with which I’m going to experiment (rust brown).
Of course I had to alter the flat car a little... The strange rectangular holes are filled, the hose on the buffer beam is removed and the hole filled and the buffer beam itself is made less high (as per RTM)
Action stuff. Chalc, brushes I can abuse, acrylic paint in several colors and clear coats, one with ‘frosted’ effect to tame down high gloss colors.
First attempts. Left lower corner is acrylic brown, above and right of brown is Humbrol enamel black. Where the right part is a bit ‘thicker‘ applied than the area above the brown.
I used a towel to get the excess of the brown acryl off, the black is untouched.
5,019
76
Well your first tentative steps are paying off as apparently has the YT watching, next experiment with a little dry brushing. A tiny bit of white on a stiff brush, wipe most of it off and gently flick over the detail. This method really enhances the detail.
ColinK
14 Apr 2017
271
140
67
Lancaster
Excellent start, I do like to see stock weathered to get rid of the factory shine and make it look more realistic, although I quite understand those who prefer to keep their models pristine.
I see you are using a mix of paint types. The brown you used was acrylic - acrylics usually dry very quickly leaving little time for you to do anything with it after application. While the black was enamel which takes hours to dry giving you plenty of time to work with it.
Experts usually say you shouldn’t mix enamels and acrylics, but I do and it seems to work provided the paint is fully dried before applying more. I’ve done loads of weathering in smaller scales and normally do the detailed work with enamels, including dark wash into panel lines, between planks etc, rust patches, grease, streaks etc. It usually looks overdone at this stage. Once that has dried for several days, I airbrush very light coats acrylics, roof dirt, frame dirt and dark grey/black onto the sides. Sometimes I’ll end with a very light spray of matt varnish, but some varnishes, especially if a thick coat is applied, can actually remove some of the paint.
Once I’ve got my layout finished, I’ll have to weather all my stock so I will be following your progress with interest.
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
And having a go on stains. White, black and gray.
I need lots of improvement here, this is not yet what I’m aiming for. But it is good fun to do and learn!
I think the secret is in the colors (which i realize is so obvious while typing this...)
being acrylic it is easily washed off.
phils2um
Phil S
11 Sep 2015
1,522
423
Ann Arbor, Michigan
United-States
Welcome to the weathering pool Henri. Once you decide to jump in you can't really go wrong. I especially like what you did on post 4. It looks great.
3,556
Yes, those last two, are a little too heavy. IMHO..
I think you are using the wrong application method? - A brush would be so much more controllable, than a dummy! :p:rofl::rofl::rofl:
Excellent, as always, Henri!
  • Haha
GAP
14 Jun 2011
4,072
950
Australia
Have a look at G-Riks blog How I weather my wagons
He used the "salt" method to weather his Simplex How I constructed a plate frame Simplex loco from an IP Engineering kit
In Aust Vegemite (Marmite in the UK?) is sometimes used instead of salt as there is no need to apply it to wet paint.
One method to apply under chassis grime is to sit the wagon on some cardboard and spray some paint in a line in front of the wagon but not directly on it and let the overspray give the dirt and grime effect.
1,721
Two different things, although the Love/Hate bit is the same and the same shaped jars
5,019
76
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
Good information guys, as usual!!! THANKS!!!
I tried the lighter ‘rust’ as when the brown(s) are applied, the surface color underneath defines the darkness of the rust, so I tried a bit lighter. Maybe I’ll mix the two colors, or try Dunny’s advice, that sounds like a fine experiment too.
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
The test subject. Chassis is also ready for rust! This is the first layer of gray, the second layer did cover it pretty well.
I want to go all the way with this wagon. I want it to look as it was abandoned in 1950.
GAP
14 Jun 2011
4,072
950
Australia
Vegemite its the health food of the nation.
Replaces all the Vitamin B that the beer drinking destroys, and as it is made from the left overs from beer making "the circle is complete" (sorry Darth).
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
Study material. This is just about perfect. It is in good shape, well maintained, but with a smudge here and there. Oh and this is the look for new build wagons, the flat cars look is in the last piccie.
Over the top:
5,019
76
Over the top:
That RTM Bogie vehicle looks interesting. Though it was a van on first look, but it is an Open that has had extra height bars addd with later fitted post holders. Cattle Truck perhaps? Almost the sort of thing that you would see in Ireland the way it has been cobbled together.
Gizzy
36,266
2,309
63
Cambridgeshire
Henri
refuses to grow up
6 May 2016
2,060
1,232
56
I do like that green Brake Van....
That is not RTM. It is from the Nederlandse Spoorwegen, in the depot of the ZLSM museum in Simpelveld, Limburg (Netherlands).
I went through some old photos in search of the ‘patina’ I’m looking for to replicate and came up with these two. They also have a delicious railbus.
