I’ve just taken delivery of a new workbench for the Operation Cabin at the CFR. It comes flat packed so I will assemble it the next time I go to the CFR.
Picture courtesy of Machine Mart.
Almost David, mind you it will take two persons to put this thing together. In the past I have made do with all sorts of tables and stuff including a picnic table as a workbench. With the arrival of the new cabin I decided to bite the bullet and get a reasonable workbench.Paul
Are you sure it's not a catch 22 situation, you find you need a workbench in order to assemble the wqrkbench…...
Paul, I have the same two items in my Garage, I did add a 25mm thick ply top to mine as I didn't consider the supplied top robust enough.I’ve just taken delivery of a new workbench for the Operation Cabin at the CFR. It comes flat packed so I will assemble it the next time I go to the CFR.
25 mm? i.e. an entire inch?Paul, I have the same two items in my Garage, I did add a 25mm thick ply top to mine as I didn't consider the supplied top robust enough.
I have an off cut of melamine which is just the right size to cover the work surface.Paul, I have the same two items in my Garage, I did add a 25mm thick ply top to mine as I didn't consider the supplied top robust enough.
White Melamine makes a great Worktop, relatively cheep and if it gets too bashed up over the years is easily replaced. Mine has been in place for 7-1/2 years now and is still very servicable.I have an off cut of melamine which is just the right size to cover the work surface.
How do you get the paint to stick on plexiglass?Today is a bank holiday in the Netherlands so I took the opportunity to finally start on the coaches project. After a lot of drawing and calculating, the saw was powered and all main parts for the coaches are ready, except for the roofs.
This is enough for three coaches. 2mm plexiglass for the walls and 2mm base.
I have used plexiglass for platforms and paint sticks to it quite well, though I tend to use cheepo black £1 shop rubbish and cover with silica sand, not quite what you would want for a coach side.How do you get the paint to stick on plexiglass?
Are you not going to insulate your cabin, Paul?The new Control Cabin starts to feel ready for resumption of operations. The electrics have still to be installed, but I am gating there:-
View attachment 266753View attachment 266754
A security screen has also been fitted to the window.
David, it took two of us almost 4 hours to put the workbench together. The plans supplied were pretty basic and whilst all the main parts were there, there were a number of nuts, bolts and washers missing. Luckily I have boxes of the said items, but it was still a faf. However I’m very happy with the end product.Paul
No need to Paul, the roof is insulated already and three of the walls are well sheltered. During the winter months a small oil radiator keeps the temperature nice and cosy.Are you not going to insulate your cabin, Paul?
