haha, how many do the IMR have ? when you have more than them start to worry.....Back when Methuselah was in short trousers, I started building an IOM saloon, using up left-over laser cuts from earlier runs. With the bomb wagon completed, I've dusted it off and resumed work:
The main reason I delayed manufacturing is that I already have enough of them:
This one, when completed, will make six, which is as many as the real railway had! Mind you, they are attractive: some have called them the most elegant narrow gauge coaches in the British Isles...
Dan, are all the locos 3 rail, or do you use the 3 rail track as 2 rail?More animation for my "O" scale layout. As the description indicates, I am starting to feel well enough to engage in a bit more activity.
This is a problem with 3D printed items..A couple of days ago I gave my Bootlane Nancy a quick prime using some of my rattle cans, before filling in the blemishes:
Yesterday I gave a second coat of primer with the airbrush (no photos), but today disaster struck, lightly sanding the chassis, and when it hit the floor it shattered. In touch with Bootlane to see if I can purchase new frame sides, but they seem slow to answer emails.
The instructions do mention they are fragile but more than I suspected.
Ouch, they look nice. Was it a 3d resin part or the Acrylic mentioned in the spec ? "fragile" not a good thing for garden railways.A couple of days ago I gave my Bootlane Nancy a quick prime using some of my rattle cans, before filling in the blemishes:
Acrylic chassis framesOuch, they look nice. Was it a 3d resin part or the Acrylic mentioned in the spec ? "fragile" not a good thing for garden railways.
Always a bit tricky with those crevices around the doors and detailing. To get a good match I tend to spray a little if the colour required into a Rattle Can Lid then brush on. Usually a bit if a challenge finding the right cleaner so must remember to use those Micro brushes next time I have a similar issue. Still a nice job.Off-white paint on, masking off.
There are a few places where the paint crept under the masking, but these will either get T-Cut out, or touched in by brush.
The inside has 0.8mm plywood cladding (now, where did I put that?) so I'm not concerned by the overspray...
Yes, the paint tends to track along those grooves due to capillary action. Mind you, I had invested in proper modeller's masking tape and used a cocktail stick to press it into the crevices, so the paint creep is, as a p*litician might say, disappointing ...Always a bit tricky with those crevices around the doors and detailing. To get a good match I tend to spray a little if the colour required into a Rattle Can Lid then brush on. Usually a bit if a challenge finding the right cleaner so must remember to use those Micro brushes next time I have a similar issue. Still a nice job.
I use Tamiya, very good most of the time, but user error, not pushing in to crevices does allow paint to track.Yes, the paint tends to track along those grooves due to capillary action. Mind you, I had invested in proper modeller's masking tape and used a cocktail stick to press it into the crevices, so the paint creep is, as a p*litician might say, disappointing ...
Did you do the paint one coat, mask then spray that colour again to seal the joints then the top coat when that had dried? This does help to seal the gaps and reduce bleed over.Yes, the paint tends to track along those grooves due to capillary action. Mind you, I had invested in proper modeller's masking tape and used a cocktail stick to press it into the crevices, so the paint creep is, as a p*litician might say, disappointing ...
Primed, plus two (red) colour coats; then re-masked and applied two coats of off-white.Did you do the paint one coat, mask then spray that colour again to seal the joints then the top coat when that had dried? This does help to seal the gaps and reduce bleed over.
