I found all of my battery packs in my RH locs had given up the ghost due to lack of use and charging regime. Converted them all to run on 9v cheepo batteries from my local poundstrecher, doubt you will have one of them nearby!Started servicing steam engines
Sent for and received Strikalite battery packs for 2 as they’d given up, waiting in the shed for meView attachment 325397
That was the problem with mine. Some run on replaceables but I like the convenience and it cost only £42 for 2 Strikalite packs and charging adaptersI found all of my battery packs in my RH locs had given up the ghost due to lack of use and charging regime. Converted them all to run on 9v cheepo batteries from my local poundstrecher, doubt you will have one of them nearby!
Cue musicThis is my latest creation. I still have to add sound and some greenery to the trees.
Runaway coach!
Oh, we like superelevationNot quite the workbench, but the railway itself. As mentioned in the coffee lounge, I have had a couple of derailments on mu curved gradient. A little (and I mean little) superelevation, hardly noticeable and the two main culprits tested and all is well. Just need some warm weather for the rest of the re-blasting
Test crew going open air for a full-on feel of the track
Lovely piece of modelling. It's making me want to attempt to do the same to my motley collection of coahesLast external details done, lighting switch and associated cables and rivets.
Followed by splashing of black paint.
Yep, if you leave the batteries charged, it's surprising how long they'll lastGot my battery powered Stainz running again. Must be about 10+ years ago had 12 AAs pack from Strikalite and RC from Ge_rik in the tender. Needed some new connectors and one bit of soldering, a new bracket for the switch panel and general fettling. Now runs fine after about 5 years non operationalView attachment 325567View attachment 325568
I did charge them periodically - unlike the ones in the steamers which had diedYep, if you leave the batteries charged, it's surprising how long they'll last
I had a 12v pack of sub-Cs in a loco which went away fully charged, but did not get used again for four or five years. It still ran, and I replaced the batteries a couple of years ago, so they ran for another four or five years after I resurrected itI did charge them periodically - unlike the ones in the steamers which had died
I thought they where up to date and modern!'Old Skool' IC's
Only if they are tiny, surface-mount, and won't do anything unless you spend three-weeks trying to program them!I thought they where up to date and modern!
