Servo Controller board 'Old Skool IC' fully adjustable for Servo Movement.
Operated by either Detection or Activation, Mechanical or Electronic, and or DCC Function or Accessory Decoder.
Amplified Output to operate Multiple Servos and or Servo Switches, or combinations of.
Servo Switch activated directly from the Servo Controller, designed around yet another 'Old Skool IC', adjustable trigger for smooth operation of attached devices, for example a DPDT Relay with a Relay Driver, or either a High Power Output to drive high voltage or high amperage devices such as the
TARR Smoker (MK3).
Further enhancements will be to replace the mechanical device as in the Relay with electronic Logic IC's.
At the present there is a 'glut' of 'Old Skool IC's' which can be often obtained for pennies.
The TARR Smoker (MK3) runs on Baby Oil available from most outlets, the picture shown of the smoke effect is from Fred & Flo Baby Oil 500Ml £2.50 from Tesco.
Additional supplements can be added, for example from the Mega Steam Smoke Oil range of products.
