Now it seems the low bit, (I don't know what it's called, the part that's pushed up in order to uncouple) is too low. It's in danger of hitting a rail at a turnout or a crossing.
I don't think those flywheels will give much different driving feel under battery R/C. What I did find really fascinating was driving an R/C Gauge 1 steam outline loco with adjustable inertia (owned by the Mr Fosworks before he took over from Peter Spoerer).I agree for track power the flywheel is a great addition, but not just for that my Roundhouse Jack has a stonking great SloMo Flywheel that makes driving it a thing you need to think more carefully about and this Hymec will have Battery Power as well so will be my first Battery Powered loco with flywheels. Be interesting to see how it pans out.
That's the problem of worm gear drives - it cannot accept any overrun. So, a weightier train will add more strain to the gearbox if the loco stutters on dirty track.Good point. I wonder if the idea is that the momentum of heavy stock is sufficient to keep 'em rolling.
Funny I have now stopped buying Rx with inertia as I find it to be a pain, I also get rid of it on my DCC Locs. I guess I like to drive with gentle acceleration or slow down rather than let a piece of software take over the task for me. Each to his own I guess, but then I run my railway a way where shunting and regular station stops are the order of the day rather than running in a circle, though I occasionally do that as well.I don't think those flywheels will give much different driving feel under battery R/C. What I did find really fascinating was driving an R/C Gauge 1 steam outline loco with adjustable inertia (owned by the Mr Fosworks before he took over from Peter Spoerer).
Now that was really great, as you had to work out when to ease off, in order to bring the train to a standstill at the platform - I could have played with it for hourswell, I did have a pretty decent go
Yep, but, I think the idea of inertia is meant to provide the feel of driving a train with however many hundred tons of weight behind you, so that shutting off the throttle is a bit like applying the brakes - the only difference being that you don't have any control over how hard the brakes are being applied.Funny I have now stopped buying Rx with inertia as I find it to be a pain, I also get rid of it on my DCC Locs. I guess I like to drive with gentle acceleration or slow down rather than let a piece of software take over the task for me. Each to his own I guess, but then I run my railway a way where shunting and regular station stops are the order of the day rather than running in a circle, though I occasionally do that as well.
Cricket field and those are the boundary fence?Test Match Special on the radio, and a project on the workbench. Ten points to whoever guesses what it is I'm making.
Now that's a thought; but no stretch of the Northern is level enough to accommodate a lineside cricket pitch!Cricket field and those are the boundary fence?
Clearly your perseverance has paid dividends. Having got it working I wonder if a Metal one (of the same design) would give more stability on exiting curves?Well eventually have my "camera wagon" working:
So this is the set up for the initial trial, the rock a temporary fix to provide some stability. So what does the feed look like:
A quick run around the circuit, not bad, well i like it![]()
I also finished off the final figure from the Roundhouse “Short Staff” range:-
Lord Angus Montcreef, Sir Garfield Montcreef’s older brother and Chairman of the CFR board of directors. He is also a fully qualified locomotive driver.
That's certainly one of the best that I have seen - sharrafter borrow itWell eventually have my "camera wagon" working:
Congrats! I love the view of the canyon at 0:45.Well eventually have my "camera wagon" working:
I think you'll find that, as a member of the aristocracy, Lord Angus has had a snifter of single malt and soda. Nothing more!But not today.. - It look's like he has had a pint of something a little 'lively', post-lockdown?![]()
