Massoth Service Tool, latest up to date version, several changes, most are only relevant for designing decoder templates.
This particular addition is welcome, as shown, is for the Read & Write values of CV’s as in the bit-wise binary code (blank box indicates a Zero, tick equals a One).
Anyone who has had first hand experience of using a Navigator to manipulate multiple CV’s and upwards of eight digits for each single CV, will appreciate any, if no matter how small the improvement is, that makes this task easier.
* LGB decoder Reset is no longer available as a functioning option, has been disabled as the Massoth CV 7 also uses the 55 value, when activating part of a decoder Reset.
The option to enter manually, or via a decoder template, either as CV 55 with a value of 55, or CV 6 with 55, then CV 5 with 55, none of the above options will have any effect, and they will not force a decoder reset, it may appear from the motor jerking that indeed a Reset has taken place , a READ back will prove otherwise.
Using Register Mode from within the Navigator Decoder programming Option will force a decoder to carry out a reset**.
Use of the improved decoder template program, redesigned an existing LGB 55021 template, with a few extra additions.
Also used for investigative look at the decoder in the LGB Track Cleaning Loco (20670),update to the existing manual will follow at some point**.
**Notes about this, and how it effects CV’s will be included in the revised documentation.
Both of which were tested using, either the Massoth PC Module*, or the PIKO Central Station with a PIKO Navigator, with it’s ability to use the different programming modes, Service, POM and Register Mode, on a set of roller bearings with steel balls.
Speaking of balls, these were on display and for sale at the G Scale event in Nottingham, parts are available to make further units up, guideline price will be around £15.00 a pair, hopefully in the not to distant future Area Meets and Local Exhibitions will start to take place, welcome to see, and try before you buy, hands on experience of the PIKO DCC system in operation using the various programming modes.
Modified Massoth M decoder template using the new CV 7 reset dialogue box.
Slightly related, working on decoder templates for the following Dietz DLE G, DLE 2M, & DLE2M-S, PIKO 3612x, and Uhlenbrock 77310 decoders.
Test of a PIKO 3612x decoder template, using genuine Massoth rollers, and a LGB 55045 Programmer, which ultimately turned out, was the source of the problem of not being able to READ & WRITE CV’s correctly, and unlike the Massoth unit it is not reconfigurable, and in nut shell, it just ain’t man enough for the task for newer decoder types, the LGB unit will however, be used for older type LGB and Massoth decoders.
Batteries, gleaning knowledge from
ge_rik
M
Michael
and
, put together a 2S Lithium polymer battery pack and a 2S Lithium-ion battery pack, balance boards, balance leads, etc.
Constructed a Plasticard container for the Lithium polymer batteries for added protection (and since then discovered a 3D printed version).
The plastic cover on the plugs are known as a Balance Plug Saver Clip.
A great device which makes plugging or un-plugging the balance charge lead, much safer and more convenient.
The re-usable Balance Plug Saver simply snaps onto the JST-XH balance plug to give a decent finger grip, no more yanking on balance plug leads.
The 2S Li-ion pack was constructed using the 18650 Battery Spacer a blend of ABS and plastic.
Perfect for creating battery packs for every use.
3S pack still to make, for use with the Tam Valley DRS1 Receiver.
And finally……………...well it had to done, and time is creeping forwards!
![Sleigh.png Sleigh.png](https://cdn.gscalecentral.net/2020/08/thumb/291879_Sleigh.png)
