I know it sounds a lot and they can on some Older Roundhouse Locomotive be a bit tricky to fit, my very old Jack being a case in point as the weight bar was not fitted with Screw but a Pin as it is that old. But the difference in running has to be seen to be believed. Jimmie’s Line is quite modest with if I remember LGB R2 Curves (he got some of them from me) and R3 points plus a Gradient in not a lot of space. Driving pretty well any Live Steam Loco on his Line will likely be a bit tricky unless it has a SloMo or is a Geared Jobby. In effect the SloMo turns the Roundhouse into a sweet docile beast and the cost is certainly well worth it. The reason I mentioned it is because Roundhouse are a very good buy new, will run ‘as sure as sunrise’ (and not be that bad out of the Bix compared with some that appear to have a Rocketbupmtheir Tail Pipe) and be pretty good out of the box to boot. Within the locs I suggested his 2k Budget would leave enough for the Loco and a SloMo with some change. I believe strongly that he wiill get great satisfaction and fun from such a loco as indeed I do with my 2 SloMo fitted Roundhouse Locomotives.£249.00 to make your loco go slower. I'm impressed. Alright, I understand the need, but £250? EACH? Someone is extracting the Michael here.
You also need to add on import duty, which may or may not be charged. A friend bought one recently and the final cost was pushing £300 before he actually had it in his hand. And not available for Lilla as there is no space between the frames for the device.£249.00 to make your loco go slower. I'm impressed.
As does turning down the gas and running at 20-30psi.In effect the SloMo turns the Roundhouse into a sweet docile beast...
I lucked out in that with my two, bit of a game of chance but it still falls within his the 2k Budget that Jimmy has whatever of the 3 RH Loco’s I suggested he may choose.You also need to add on import duty, which may or may not be charged. A friend bought one recently and the final cost was pushing £300 before he actually had it in his hand. And not available for Lilla as there is no space between the frames for the device.
SLIP ECCENTRIC REVERCING.
If he went that way, having had a Slip Eccentric Loco in my early days of Live Steam I would never go for one again as non-automatic reversing without the hand of God is complete pain. One or two RH earlier Locomotives had it most likely the cheeper end ones but I see that they are not made just now
Max I specifically looked at tye RH list of puffers and could not see any Slip Eccentric Locs, which ones are they?3 slip eccentric models still very much in the current RH catalogue I provided a link to earlier Jon. But, as the "artfull dodger" has mentioned they can be upgraded to the more advanced "simplified walchaerts" spec - but then you might as well had gone for a Katie or Bertie in thr first place. You pays your money and makes your choices. Neither the R/C nor valvegear upgrades are factory fitted options on the "basics" - it's do it yourself or someone to. Max
Lots of good sound advice; just for some clarity, most of my curved track is LGB R3, but I have some Aristocraft 3 ft radius, my R1 points are going, my Bachmann doesn't like them, my gradient is around 1:25. Having been in touch with RH, it would seem most of their locos will manage this.
Second-Hand - as Jon has pointed out, as a novice I would steer away from this.
Thank you all for your responses, 30 posts and no real thread drift![]()
Something must be wrong, ShirleyLots of good sound advice; just for some clarity, most of my curved track is LGB R3, but I have some Aristocraft 3 ft radius, my R1 points are going, my Bachmann doesn't like them, my gradient is around 1:25. Having been in touch with RH, it would seem most of their locos will manage this.
I am sure I asked not to call me ShirleySomething must be wrong, Shirley![]()
oh look!!! There's an otter!!!!
