That should please Gauge 3 bods who may also be a market for you.Thank you! I will do a scale 4 wheel version of the kit to match the GRS coach
The last day or so have seen some more work undertaken. We are at a rolling body stage now.I have never built or for that matter ever thought of building such a kit so this makes very interesting reading and the step by step build is very informative with the little add ons and niggles you have overcome,thanks Jon and looking forward to the end result
Thanks Matt have mounted the bogies such that they do not hit the side frames when put in place.Looks great Jon, thank you for all your efforts.
Worth checking that the side frames don't restrict movement too much, but I can get the coach around my 2'6" radius curves without issue, so I'm sure you will be fine.
Yes I noticed that after I had put the body on the chassis, it also effected to tumble home a little and has lost the bottom frame. I think I will correct the gap with a long thin length of cut each side from the spare ply. I have just cut a similar thin piece to make right my small error on the steps in that the bottom step should have been closer to the front as you said in the instructions!One thing I've picked up from your photos is that you have aligned the body with the bottom of the chassis and when I built the prototype, I aligned to the tops of the frames, giving a step from the body to the chassis.
I think you may need to do a little bit of shaping to the roof to get a smooth transition, but let's see how you get on. I can easily extend the body slightly so that a flush fit can be achieved if required.
Yes thanks Matt have the strengthening arches to add, they will be next to do once the current side extensions dry off. Good plan to add the strengthening arches have you thought a bit about making the roof perhaps 2 thin planks wider as I have been working on?Nice one Jon. The kit contains strengthening arches for the balcony roofs, so you could substitute your deep frames for these and still have the roof as removable. I'll include some roof supports in the kit to make it removable.
Yep, can easily adjust the width as required.Yes thanks Matt have the strengthening arches to add, they will be next to do once the current side extensions dry off. Good plan to add the strengthening arches have you thought a bit about making the roof perhaps 2 thin planks wider as I have been working on?
Looking good Jon. It will be interesting to see what the final paint finish looks like. I brush painted mine with multiple coats of slightly watered down acrylic, but I feel I could have done more sanding to flatten the grain a little more.Have been doing lots of little jobs during the week and have got to the stage where the coach has started to be painted and my mind is pondering long and hard about couplings.
However first up was to extend the roof profile a little, this was mentioned in Post #30 where I showed the paper being attached to the narrow strips cut to extend the roof profile. Below you can see how that was all attached to the inside of the roof. Befor spraying a little filler was added to the joints and sanded down to give a good flat roof profile on top.
Here that can be seen after having been glued in place, I have also added shorter internal bracing where they will butt up to the Coach End Frames. I achieved fit location by placing the roof on the coach and marking a pencil line inside the Frames at each inside end of the coach. This has given a nice snug fit when they had dried and the roof was refitted. Removable roof will allow access for figures and bogie mounting plus of course at this stage painting and seat fitting. Should I wish it a screw could be fitted to the slot to attach the roof more permanently into the internal bracing.
Here I have started fitting leather strips to the seat units. Luxury indeed for the punters on my line.
Painting via Halfords Rattle cans has commenced with the body and inside having an initial spray of undercoat red. The windows will be masked inside for the external painting job as I feel that the red (oxide) will be fine inside.
Various parts have been sprayed up black, some can be seen here with the wheels having been masked to preserve the genuine rust on the wheels.
Thanks Matt. Primer/Sealer will do the job pretty well but on this I have given the light dusting that had not raised the grain overmuch. I am hoping that the next sprays of colour will keep things pretty flat.Looking good Jon. It will be interesting to see what the final paint finish looks like. I brush painted mine with multiple coats of slightly watered down acrylic, but I feel I could have done more sanding to flatten the grain a little more.
Jon I use this, and find very little if any bleed is used according to the instructions, only use the paper stuff for general masking:I talked in Post 18 and 22 about using card beading, I got this very wrong and should have used Slater Microstrip instead, annoying thing is I have some in stock and considered using it but though card would work out better. How wrong can you be? The other thing I have done wrong was to not use Block to seal the wood prior to spraying, this would have sealed the wood and help prevent the ply roughing as the grain does tend to lift a little, it would also have helped with the card possibly. But keep on never minding and onwards.
Having allowed the White/Creme to dry it is time to do the Red.
Inevitably there is likely to be some slight bleed through with wood, I fix with this by spraying some of the base colour into the tin lid and brushing it on the offending bleed places. As you can see after a very light sand the 4-5 coats have given a pretty good covering.
Having come up with a stunning plan I am now onto coupling fit and adding the sundry details.
