Woodlock Logging
Do the motors have to be connected to the 'multi decoder' when put on the programming wire all together or one at a time?
As I understand it, you only need one motor on the LGB decoder..
I have not 'played' with a Massoth unit.. You may need a motor on the channel you are programming?? - Mark will jump in and tell, I am sure!
You have to connect a point motor to give the decoder a 'load' to sense for programming....
A few pictures from this morning.
P1020087.JPG P1020088.JPG P1020089.JPG P1020090.JPG P1020091.JPG P1020092.JPG P1020093.JPG
Into each output of the point decoder? So I would have four motors connected to it, or one at a time working through each output with a motor?
Hi Duncan,
You only need to connect one point motor to the decoder. Have a look at Page 16 of the CS3 Manual. A link to the manual is here: https://static.maerklin.de/damcontent/3e/38/3e388001f5fcefb4368dddd635e117121482230202.pdf
Here is a link to programming the LGB55025:
http://www.beathis.ch/lgb/digital/55025/55025_e.html
Regards
Martin
Fence is my biggest frustration from a picture taking point of view so I went to B&Q and found some off cuts of AstroTurf to disguise my fence where the line runs along side it. Had a few trains out too.
A fair few locos on the railway today as I add my dad's locos to my CS3 set up. Loads more to go another day.
P1020110.JPG P1020109.JPG P1020106.JPG P1020104.JPG P1020099.JPG P1020102.JPG
And a little maintenance. To stop ballast slipping down the embankment I built a new wooden returning wall.....
I have battled driving rain. Wind. Snow and I'm bloody cold. But..... I have put my point motors on, all wired up with the decoder in the box. I love this CS3 set up. Here are a few pictures.....
20170212_154720.jpg 20170212_154707.jpg 20170212_153826.jpg 20170212_153803.jpg 20170212_153755.jpg 20170212_153748.jpg
Well done!
I like the economical use of using 4 motors for facing points only and allowing the 2 trailing points to 'push through' on your passing loops....
Well done!
Ha. That was me been a cheap skate northern England Yorkshire type person. But that middle road mainly gets used as a siding from the other end. I will in due course get a motor on it and maybe some signals. But for now I have just committed to my first MFX loco. The LGB Porter.
Ha. That was me been a cheap skate northern England Yorkshire type person....
Same as I then?
Originally a Leeds lad, so I still have short arms and deep pockets....
New toy. The MFX sound is brilliant. It can whistle and bell for as long as the button is pressed. Love it.
