But then, how many times does the indicator in your car tick before the relay fails?
Depends if it is the 'little old lady' who never cancels it??
That component is designed for that purpose..
I was thinking that a capacitor's action would reduce the bounce."
However, standing on the end of the gangplank while dispensing this wisdom - I suspect that you wouldn't hear bounce because the chuff is largely dispensed by capacitors, (one of George's mods was to shorten the over-long hiss on the Annie sound with a heavier capacitor).
As to rounds per minute, and lifetime expectancy ................... ahem.
But then, how many times does the indicator in your car tick before the relay fails? Yeah, I know, probably not used that much of you drive a Beemer, but most average cars use them on a reasonably regular basis "
Well, it's speculation if you could hear the bounce or not, shortening the chuff would seem to make any bounce MORE evident.
One trip around the layout would probably result in almost a year's wear on your turn signal indicator... think about it.
If you're prepared to wait 3 weeks, you can get one for £2.83 from Hong Kongyep, SS relay might be a good choice, but a bit more expensive, and I am not sure they can have an independent ground, but maybe you can tie the grounds of the loco and the sound board..
bounces are hard to get rid of with a cap, you might be affecting the chuff once again... but the bounce is not the same as electrical noise, like a .1 mfd cap would handle.
Will be interested in your experiment.
(ss relay maybe like this: Kyoto Electric KF0602D DC-to-DC Solid State Relay, 32 Volt, DC Input, 2 Amp, 4-Pin, 1.4"L x 0.3"W x 0.9"H: Electronic Relays: Amazon.com: Industrial & Scientific )
No need for drastic action sir, I did a bit of research on the little gizzmo that you posted, and we're back to the optocoupler from the Aristo slope back tender thread - now I understand what the optocoupler doesAhh a challenge!
36" should be the driver diameter, or circumference of 113 inches, or the circumference is in 1:20.3 is 5.57 inches
with 4 chuffs per revolution, that is 1 relay click every 1.4 inches.... so 1 foot on your layout is 168 clicks of the relay, a scale mile is 260 feet, so 4,368 clicks for a scale mile... run for an hour at 25 scale miles per hour you have 109,000 clicks
a turn signal relay normally is between 1 and 2 seconds per click, let's pick 1.5.... so 40 clicks a minute, and if you are sitting at a light for 3 minutes you have 120 clicks...
I think you can see that the relay in the locomotive will get properly exercised and will easily outstrip your flasher relay
run your train for an hour a day and your have to sit with your flasher for 5 hours for the same number of clicks.
So pity your poor mechanical relay if you choose to use one, it will probably commit suicide.
Ahh a challenge!
I'll leave George Schreyer to sort out the rocketsNo need for drastic action sir, I did a bit of research on the little gizzmo that you posted, and we're back to the optocoupler from the Aristo slope back tender thread - now I understand what the optocoupler does
I'm obviously a quick learner so I wondered if your mate George needed any help with his rockets
chuffin baffled
Yep, the Bachmann Annie board operates on the easiest of all triggers - you have four bars across the axle with two contact strips, and they close the circuit 4 times per revolution; Connie is the same: seeemples.If done correctly.. Can greatly enhance the musicality of the sound..
I have lost the 'thread', on the elektrickery front, on this one.. But a niggle about normally-open, or normally-closed contacts comes to mind? - You may also find it is actually the 'edge' (transition from + to -, or vice-versa) that actually triggers the 'chuff'??
I'll let John jump-in.. He is across this one, more than I..
Hmmm - it didn't say that when I first looked at it, but I have since seen a reference to that.Hmm!, this is a Triac optocoupler?, mainly for AC based applications.
Waiting for bits to construct a test rig, will get back soonest.
