I do not wish to raise the discussion on the merits or not between Battery and Track Power, my personal decision has been made it is Battery and Live Steam for my own future. Well except for perhaps odd sessions in the Shed during the Winter but that must be a different story.
However as with all things, issues always arise and with the lack of need to clean Track comes the issue of Crud. Not dirty Track, but small stones and objects that are deposited on the Track by Rain, Wind, Urmsleygurmsleys or whatever. These are normally observed and picked up when using the trusty LGB Cleaning Block, but sadly missed now. So what is to be done? Well a cleaning Wagon of course.
This track Cleaner has been seen before and the pic below shows how It was as used on the Ruschbahn and on occasion here. The Middle Bogie is a Norms Model Supply Ckeaner procured by Andy from the USA. Has
www.choochoostuff.com on it as well, not sure if they are still in existance but it was a pretty useful beast. I knocked up the setup for Andy at some stage and its utility can be clearly seen here. Also to be seen in the pic is the Brush that I obtained from Poundstretcher, the £1 price being reduced at the January Sale - result.
The Track Cleaning Bogie was removed for possible future use (never ditch anything) and one ends Bogie was reverced together with the block at this end being Srewed and Glued right on the end of the Chassis. The Cleaner can be seen to better effect below.
The Handle of the Brush was chooped off, the wood being placed in the Log Burner pile. Then the remaing bit was screwed onto the moved block with a few subsequentky shortened Coffee Stirers used to block the Brush out so that it sits vertically. The view below shows the final setup.
In use it is better pulled by a Battery Loco which must navigate all the Bumps and Lumps in its perambulation round the line. If Propelled the Bristles catch between the Wheels and Rail. A further benefit of this beastie is that said crud is sometimes removed from between Point Depressions and Check Rails as well.
