Greg Elmassian
Guest
Wow, a year and a half old thread brought back to life!
In any case, that track cleaning device is no longer available, nor the website.
That cleaner was marketed under "Norm's Track Cleaner", reviews were not great and concern was that it flattened rail heads by going crosswise.
In any case, that unit did indeed grind oxidation off the top of the rail, along with a fair amount of material.
I'm commenting because I found that the phrase "track cleaning" is often very misleading. I break it down between:
clearing (removing large bits of debris, like leaves, twigs, ballast)
cleaning (removing dust, dirt, tree sap, etc, but NOT oxidation)
oxidation removal (the part of the brass rail that won't conduct electricity)
I use different methods for all of these.
for clearing, I have a powered rotating brush, that also creates a breeze, will sweep anything away:
for cleaning, I use a "wet wipe" on a pole, that removes all greasy deposits:
not solvent based, more like a household cleaner for walls and counters
and for oxide removal I (used, now stainless rail does not need) I used various methods:
this one worked well:
All of this an much more on my page on track cleaning/clearing/oxide removal:
Track Cleaning
Track Cleaning
