tramcar trev
Ok my steam tram motor has a 4.8Ah blue battery in it. Symptoms are that the motor has no torque.... Its driving a conventional Bachmann tram motor/chassis/wheels via an ESC. I have changed the ESC a few times from different brands I've swapped the wires over ( some esc's only give 80% in reverse) still the thing misbehaves. I am wondering what the go is. The smoke unit which draws an amp works well and with smoke on or off makes no difference, it still makes all the right noises but crawls along until it hits a curve then stalls. Battery voltage is around 12v fully charged....
Power it via a 2 amp bench power supply and I get wheels slipping.... Must be the battery is all I can think of.... I may have to rip the blue battery out and make up a Ni-Mh pack and see if that's the problem....
Thoughts from the floor?
