GAP
G Scale Model Trains, 1:1 Sugar Cane Trains
Beddhist said:Well, I'm just blown away how quick that went: ordered on 10th, shipped on 11th, arrived today (15th). It looks like the box was not opened by customs, but by Fedex:
[attachimg=1]
In the paperwork were 2 copies of a Lithium Battery Safety Document, which makes reference to 8 different ICAO/IATA packing instructions. It also states that the included batteries have a max. of 20 and 100 Wh per cell and battery and contain a max of 1 and 2 g of Lithium.
After all this and reading the charger manual in Chinglish I am starting to wonder whether I have bought the wrong thing. They are adamant that the batteries must be disconnected and removed from equipment while charging. Another thing I didn't know was that not only do you have to connect the balance leads, but the main leads as well. So much for installing a charging socket. The manual also says that the charger must not be used to charge batteries equipped with protection circuits. I guess I will now need two of those as well.
For the rail truck and Davenport this may work, but I will need a different solution for my Piko 204 Kamel, as you can't remove the body easily. But it's probably big enough to take a Pb battery.
In another life I worked for Aust Post in the customs section.
We opened the parcels for customs inspection and sealed them back up with tape that had "Repaired by Aust Post" on it, so FedEx most likely opened and sealed the parcel for customs.
