Have tried various methods, glue, drilling the sleeper bases to match the screw holes on the bottom of Aristocraft track, or tapping LGB track to do the same.
Finally settled on...
Butting up the check rail to the moulded chairs on the sleepers, then drilling down through the foot of the rail and the sleeper at a slight angle, tap the rail to take a fishplate or track base screw,
trim off the flash on the underside of the sleeper and open out the hole slightly, realign everything up then insert screw from the underside.
The "Collins Cutting" bridge" has all the methods described.
The screws are staggered on the lengths of rail, in this case offcuts on the "Collins Cutting" bridge, as I thought they may wobble slightly, but apparently not so,
for the "Lawnmower Bridge" they are all just fastened on the inner face.
As for the bend in the rail, it just happens to be the length of the jaws of the mini vice I used.
Thanks Gordon..
Others seem to have 'just' glued the check-rail in place.. I can't see that lasting more than a season, or two??
