Chris Vernell
45.29 N, 75.75 W
Speaking as someone who is now on his fourth, or is it fifth
, rethink of how a certain simple junction should be laid out ...
Yours looks good
Yours looks good
DCC lights - I like it.![]()
Nice lamps now that the extended pole has been designed and inplemented. Just wonder if you are changing bulbs, would bright LED's fit? You could probably run a complete layouts worth on 1 decoder with perhaps 2 separate lighting zones as well.I may have to make decoder plural, as each bulb draws 100 ma at 12v, but I was planning to extend the bulb life by running at 9v.
Also as I have broken a bulb head, I might see if a lgb 5v bulb will fit. (Note to self, need to get some more 5v bulbs.)
Anyhow decided to see how one looked in the fading evening light yesterday, or dodgy picture time...
You get a better idea with shed lights on, which sort of defeats the purpose...
...still a dodgy picture though.![]()
I have thought of LED's if I could just get a fine enough connection pins as it were.
It's a railway platform - uniformallySo back to my station lamp project, remember that, well I have abandoned it....sort of.
I found these on that bidding site, from China, so why not.
...advantages over my light/pen shaft lash up are...solid one piece unit, taller, low milliamp 3v leds, as compared to 100 milliamp 12v bulbs. fixed heads, and three of them more illumination, and that threaded bit on the bottom, which smaller than the drilled holes in the platform.
...if I only had some small rubber washers I could use to act as bushing...well...
...so I bought 16 of them, will have plenty of spares...
...test fit within the last few mins...
...another advantage, the colour blends in, so the do not stand out, when viewed from "outside" as it were.
Not sure how to arrange the heads as it were, uniform or staggered, 1,2 and 2,1 facing the platform edges or set them set them centrally.
This search came up with lots of possibilities and a lot that were no good for you!Missed opportunity to run stuff this weekend, busy with other things, as posted in todays Coffee bit...
But this afternoon has resulted in some jobs ticked of the list...
Levelled the dropped track section...
Bridge(s) washed to shift bird crap...
Unsupported point section is now supported...
Two road MPD., is now three road, as I have laid some more slabs...
...more progress in the last few hours than all of last year.
Now look at those vacant spaces either side of the MPD., you would think they were crying out for a building.![]()
