Chris Vernell
45.29 N, 75.75 W
Micro-Smaug!... in this hobby you can not be disappointed for long as something will turn up to bring a smile...
Glad it's worked out for you Gordon, just the jobHaving been initially let down in the supply of a curved point from a retailer, a fellow member was in the process of exchanging his Piko one for a Trainline one, so the opportunity for the Piko one was too good to pass up.
So today it arrived...
...It was given the once over and the fishplates replaced with Massoth clamps as per group standards here as well as the installing of one of my pass on the left reset springy springs...
...so a positioning trial fit to see where it would fit in...
...so pending the laying of the trackbed slabs, it was looking good, but I wouldn't have time today to do that, or would I...
...and so this is the current state of play as it were, just need to install a short curve, trim the straight back at the joining point, drill and tap the holes for fishplate screws, assemble, then test.
But that will have to wait for another day probably Sunday as tomorrow is taken up with something pre planned.
Not for my brain, enough trouble with 1 loco! Re cement, best to clean up off slabs before fully dry if you can. Lump hamner and cold chisel can easily undo work when trying to ckean up hard ment.More work on the tunnels yesterday, which means that they had to be clearance tested again...
View attachment 329398View attachment 329399View attachment 329400
...don't worry the excess cement spills will be cleaned up in due time...
But why just stop at tunnel clearance tests...
View attachment 329401View attachment 329402View attachment 329403View attachment 329404View attachment 329405View attachment 329407View attachment 329408
...now you should try using two Navigators to control three trains, leaving the fourth setting for route setting![]()
Thanks, I wonder how secure that would be if dropped. On my Tx’s I put in a Split Pin with a loop and the clip on Lanyard which does support dropping the hand unit ok providing lanyard is round my neck.It's basically a cat cable connector with the ribbon, so it just plugs into the connector plug.
So, while teaching my grandmother to suck eggs, I assume that you've checked that the skates aren't too stiff ?So having posted on another part of the forum using my phone, may as well do the same here with todays activity.
The rain has stopped whilst I was pottering in the shed, so now the newer Crock has an additional set of power pick ups on one of the inner wheelsets and a second traction tyre wheelset.
Mind you given the size of the weight lump over the bogies, the 3 oz I added to the older Crock feels rather feeble.
