Finally starting my layout
Went to the landscape store today and picked up some more rocks and some more plants. I think I like it. Hopefully it will grow on me.IMG_20180116_111244838_HDR.jpg IMG_20180116_120053134.jpg IMG_20180116_120115306_HDR.jpg
Great little railway Jack. I thought you must be in a warmer place than I if you're able to work on your railway now. The Little Big Haulers look great in their setting. Smaller locos and rolling stock are the way to go. They make the scenes more believable.
Thanks for the nice comments. I will need to cover some plants tonight. Here in South Florida it may get to 27. Brrrrrrrrrr
Don't worry about it..
It will 'green-up' over time, and you will not be able to see them.
Great progress!
Got to run some trains while I was putting in the road. My little MDC Big Hustler is pretty powerful. And a little hualer on top. I don't know if I will use the buildings I put out for main St or not yet. They were some of my first buildings and a bit to like maybe . What you think of them..
I think they look fine - you need to add some more!
Thats looking really good Jack. and a road can be built anyway you like if it looks right.
i noticed you had a track joint come appart - have you found the joiner (fishplate) securing screws under one of the sleepers on each track section, hed in place with a dob of wax - these fit the holes in the rail ends.
Thanks Guys. Yes I found the screw with the wax. All the track I have in use right now have the split jaw joiners. They are awesome but expensive. I may need to try and use the old joiners on some of the straights with a jumper wire possibly. I can't believe after like 4 years I'm finally building my railroad...feels good...
Great - I find the little screw joints pretty good but you cant beat rail clamps.
Filled the pond last night and to my joy it still had water in it this morning.. I need to figure out how to hide the pump and hose . I guess over time the pond will grow Moss is something that may hide it some. Not sure how to fix this problemView attachment 232316 View attachment 232317 View attachment 232316 View attachment 232317 View attachment 232318 View attachment 232319
Can't you hide the pump and bits under the overhanging rock? As PhiliP said, it will green up in time, but if you're not careful it'll get bogged down in pond slime, so putting the pump on a brick (if the pond is deep enough) helps keep it clear
Thanks will do. It is already starting to become less noticable. I like the idea of keeping the pump off the bottom a bit.
