metzbahner
TOP FIVE MYTHS EXPOSED ABOUT ELECTRIC TRAINS WHEN CREATING A GARDEN RAILWAY....
M#1. Electric Powered Trains need extensive track cleaning and expensive, time-consuming maintenance.
Answer: Wrong!
You can run digital or analog trains in the garden without spending over the amount you would run battery power engines. The solution is to use brass or stainless steel rail-clamps. If you are installing a permanent set up, take your rail joiners OFF your tracks. The rail joiner traps the most non-conducive particles that will make dead sections. The rail joiner was made to connect sectional tracks indoors for short-term only. If you don't plan to remove your tracks for some time, remove the rail joiners and rail clamp the sections together with a set of brass or stainless steel rail clamps. There are many, low-cost clamps on the market and you'll rarely if ever have to deal wtih dead sections once installed.
M#2: Metal wheels are required on rolling stock when running electric trains outside for any extended period.
Answer: Wrong!
Again, rail clamps will keep the current flowing through the rails. The MYTHS about plastic wheels stopping your engines is bunk - unless your plastic wheels are covered in car grease or the temperatures hit 130 degrees. The myth was based on using metal wheels on rolling stock while the railway had rail joiner connected sectional pieces. In sectional track set ups with rail joiners, yes, the metal wheels may in the short term prolong the conductivity. But, if you are making a permanent set up, using rail clamps will negate the need for metal wheels to help keep the track clean. With rail clamps, your track can be very dirty and the trains will not become jerky and jutting.
M#3: I need to buy an expensive track cleaning attachment or locomotive if I desire electric powered or MTS/Digital outside.
Answer: Wrong!
Sorry to repeat myself, but rail clamps will solve the issue. Especially if you remove your rail joiners and install the clamps directly on the rail. The less sectional pieces will also help the transfer of digital signals, but rail clamps can be mounted so tightly the transfer between sections is 98%.
M#4: I need to solder jumpers to the rails to get great reliability with electric powered trains outside.
Answer: Wrong! ....see above.
M#5: If I use rail clamps, the sun's intensive rays will cause the entire railroad to get out of sync and track kinks will result in damage.
Answer: Wrong!
Even if you are in Texas or Arizona, a tightly clamped LGB sectional set of rails only expands or contracts modestly, and you can either buy a small sectional "stretch / expand" pieces of track, or when you clamp the rail clamps, leave 2mm/3mm space between the rails. Leaving space between the rails in the rail clamps will solve most heat issues in most states.
Top Five Reasons To Run Electric Outdoors:
1. No time-consuming and expensive mods to Factory purchased engines
2. Quick set up and minimal maintenance - Two motor battery engines run only 1-2 hours on charge
3. Engine resale value remains high - R/C equipment may become obsolete
4. With rail clamps electric conductivity very reliable - run Digital in the garden with automated signals and track controls
5. Many DCC and Analog products from various manufacturers compatible
Was this helpful? Feedback appreciated. No, I don't sell rail clamps...LOL....but I LOVE THEM! They REALLY WORK!!!
Answer: Wrong!
Answer: Wrong!
Answer: Wrong!
Answer: Wrong!
