Getting a Playmobil shuttle unit to work
Being a shuttle unit, I assume that the loco will pause at the end of the run before returning. The module isn't stuck in the pause mode, is it?
I was wondering in a similar frame of mind but more "does it have to be on a track set up with a split track with diodes towards each end to work". Also, I know of at least one shuttle where the loco has to be positioned so that it starts and runs right to left when setting things up and so I always try to follow that "rule" with any shuttle. And, of course, the loco has to be on a piece of track between the two diodes.
I’m not sure how I’d check this apart from looking at the relay? It’s all way over touching the contacts which I’d guess would be closed for a power feed forward/reverse
There are no known extant instructions for this item but I've always followed what I do with LGB and other shuttle makes.
No instructions, it was acquired in a job lot. Surely the circuit board just sits between the track and the controller, each having a red and blue wire
I've attached some images to this message of a store shuttle unit which was previously on ebay and included instructions in German. Is this the system you have? The instructions say It has a couple types of magnets which I assume it uses somehow, and the train itself clearly appears to be specialized for using the rc motorblock with an electric track(but perhaps is also specialized for use with the magnets?). I don't know how it works, but maybe someone else can share some insight based on these images, that is if you confirm it's the same shuttle system.
It is a different beast..
Designed for track-power.
Yes, you feed power in, and connect to the track the output, but you also need two gapped-rail sections, and a couple of diodes..
The shuttle detects when the loco passes one of the diodes, and stops the train.
After a delay, the train runs back the other way, until it passes the diode at the other end of the track.
Excuse the nuts from the power to circuit board, they were just used to roughly nip the wires so I could get this photo. This is how I thought it would go together.
Power - Shuttle unit - track
Just to confirm the circuit works when the circuit board is removed from the equation
Mine is just a standard track powered train, the shuttle is a playmobil one that came fitted to a buffer and the board is hidden in the buffer by sections of black card slotted inside
I understand that I’d need diodes over gaps of track for the shuttle to send the train back and forth but surely with no diodes it should power the train anyway?
Yes, but there could well be a delay, before the unit supplies power to the track. - The 'full' LGB units have a maximum delay of (up to) 8 minutes.
I thought even the simple offering, had a couple of pots to tweak?
The only problem now is deciding which pair of wires go where, track or transformer, and I have no photos to show this. What I would suggest is to set up alength of track with a split piece either end (with sufficient stopping room beyond with the diodes in (both on the same side of the track and "letting" current through in the appropriate direction) and then connect the shuttle to the track between the two split pieces, e.g. around the middle of the layout. If your controller has both an outlet for control and an outlet for auxiliary use, the wires to the track go from the control outlets to the track. If you are using a Playmobil controller, the outlets are the red and blue ones.
So I took the board to work yesterday and had the electronics guy test it, when I had it attached to the controller and controller switched on he tested the other two wires with were reading a current of 12v.
So unsure why there should be a delay
Pedant-mode:
A voltage of 12V..-Sorry,it just grates.. ;)
The unit could be faulty?
The problem with checking with a meter (without a load) is that a voltmeter is a very high resistance, so you need very little current to 'see' a voltage.
Despite it not having anything to set the delay times, I think it should be wired the same way as the filly-featured LGB unit.
Follow the breadcrumbs, to the LGB instructions:
Your controller is replacing the little unit they supply.
Pedant-mode:
Don’t worry I knew what I was saying as I was typing it. I was just trying to give all the info I had considering the 12v obviously not under load. Haha.
I will have a look at the instructions that you have sent, thankyou
