TTaannggss
Hates T.P.& r1Cur. Retired for 3 after 40 in Hosp.
I'm a very strong track power advocate, I could not afford battery power given I need remote control and desire the best sound and long run times.
You might be able to run steel strap, but you would need a thin preservative coat of a very light oil/solvent, like kerosene. It has been done.
One thing might be to make a small test oval and try a few things out. The climate makes a big difference.
Another item: you don't need to fix rails/ties so they cannot move, it turns out that causes more problems. The easiest is letting the track "float" in ballast like the real railroads do. the only difference is you need larger size ballast (hint: a real raindrop scales to about 8 inches on our models). So the coarser ballast says put and does not wash away as easily with rain.
Lots of ideas here.
Lots of ideas here.
Ok how about the Lionel freight car? I like it and will order one to try it out. If I like it I will order more. I want to see what the check out price is before I order one ..yaBachmann track is hollow tin plated steel, so fragile, bends easily, does not connect to other track and rusts easily.
Do not buy it for outside.
greg
