Many thanks Jon, I hadn’t seen those very useful threads. We’ve a Dunelm just down the road.
Be quite easy but if you do that it may have been quicker to just scratch build in the first place.Still waiting for glue to dry on the factory building and coaling stage. Picked up a goods shed kit from Arcadia yesterday - I had planned to scratcbuild one, but the kit will be quicker. Made a start on it.
The kit includes a base which I’m not going to use, hence the balsa bits to keep it square. I’m thinking it would be more Harz like if the wood strips were vertical, not sure how easy it would be to cover it in coffee stirrers. Perhaps add a low concrete base too.
the only answer was to find a slow running small motor and mount the fan directly on the motor’s shaft.
Did you try a bit of washing up liquid in your water spray? Most likely the water just did not penetrate the glue without any, surface tension you see. Also with my mix of 50/50 Water and PVA I always add a drop or two of Washing up liquid. When making that mix it is worthwhile using luke warm water just to get it all nicely mixed in. Oh washing up liquid last after you have shaken it all well. Likely at this time if the year unless you are in a heated room the glue can take an age to dry.Back home after a long weekend away, including a visit to the excellent Spalding Model Railway exhibition - I dropped my wife off in Spalding at 0930 and said I would meet her at 1500hrs at the show, fully expecting to discover she had been sat in the van for a couple of hours and bored, amazed when she said she could have done with longer. I managed to get a few important bits from Squires tools. She spent more than me.
The first item from Squires was a slow reving motor, which today I’ve fitted in the big building seen in earlier posts. It now has an extractor fan which works.
I laid the platform surface using Woodland scenics ‘course cinders’. To glue them down I tried Delux Materials ‘ballast magic’ which is a dry powder you mix in with the ballast (cinders in my case), spread where you want it, spray with water and that activates the glue. Did all that last night and this morning a fair proportion of the cinders were not stuck down. Not good, especially as ballast magic is quite expensive. Added some dilute pva and still the cinders are not stuck down. I’ve added more pva and am hoping it sticks this time.
Mranwhile I’ve painted all the plaster on the above photo. Its starting to look like a railway now. No pictures today as its too dark.
Yeah, have had the same problem at King's Lynn, Watlington, Downham Market ...............Still waiting for the glue on the platform to dry.
Take a brolley then....Yeah, have had the same problem at King's Lynn, Watlington, Downham Market ...............![]()
