I’m now at the stage where I need to decide on point control. When I laid the track all the points already had LGB point motors attached. I also had several MTS 55025 point decoders which had been outside for 10 years, then stored for 5 more years.. I tried to reprogramme them using my ancient MTS system but with no success. However, as the 55025’s still responded to the addresses used on my previous layout, I was able to use them. Hence I wired them in, although the point adresses are not very logical for the indoor layout. By powering them off the track there are no cross baseboard wires, which is very helpful.
I only have 5 points, two form crossovers and one for entry into a siding. They are on three different baseboards with one crossover being on the board that lifts out for access.
I’m now starting to reconsider the point control. Ideally I would like the points to have a indicator attached (as on the HSB) to better show which way they are set. I’m not sure how to do this.
As all my MTS stuff is about 15 years old and I guess will expire at some point, I’m wondering if it would be better to remove the point motors and have the points manually operated? I could do this quite easily using a rod under the baseboard. Any thoughts appreciated.
