I think you may be understandably confused by the terminology in this area.
The wiring in your loco (not having seen it but I believe this to be the case) enables you to have working lights at the front and rear, and something called "function output 1" or "function 1" or "F1 terminal" even (confusingly) F1. This is not the same as function key 1 on your controller. This function output 1 is usually manifested as a pair of pins or socket on the circuit board, into which you can plug some device. Usually it is used for a smoke generator.
These (F1, front light, rear light) are all independently switchable. With early MTS and the 55021 decoder you can use the "light" button or any of the keys 1-8. The confusing bit is that these keys are sometimes called F1, F2, F3 etc.
The keys that control function output F1, front light and rear light are configured in CVs 51, 52, and 53. You can choose to have the "light" key control any of these. So if you wanted you could have the "light" key controlling function output 1, function key 1 turning the front lights on and function key 2 turning the rear lights on. Not sure why you would do that but you could. The important thing to understand is that the relationship between the key you press and the thing that controls is defined by you in CVs.
The usual way to set this up is so that the "light" key turns the lights on. So CV52 and CV53 would be set to 0. But there are additional settings for the front and rear lights, so that you can have the front ones on when you press the "light" key but only when going forwards (by setting CV52 to 128 instead of 0) and the rear ones on only when going backwards (by setting CV53 to 64 instead of 0).
The setting for what key controls function output 1 (as I said usually smoke generator) is up to you. If there is nothing connected to the socket or pins then it doesn't matter, you could leave it as 1 (CV51 = 1). If there is a smoke generator connected then whatever key you choose will turn that on and off.
Earlier someone suggested you increased the voltage for the function output F1 (CV49) and lights (front and rear set by CV50) to max (32 = track voltage). I would put those back to 5 or 6 and use a voltmeter to measure what voltage is generated for the lights and function output F1 and then adjust accordingly. If you have a 5v smoke generator attached to function output F1 and you put full voltage through it with no smoke fluid in it will glow red hot then fail.
Sorry this is so long, I wish I had more time to make it shorter and more concise, but I hope it helps.
With those configurations settings it should work. I'm running out of ideas. Can you check the 55021 decoder is correctly and fully plugged in the direct decoder interface? All I can think is there is some loose connection between the light pins on the decoder and the direct decoder interface socket.
Are you by any chance coming to G-Rail?
If so, warn me, and bring it with you.. I will be on the Chasewater Railway stand / layout.
Decided to swap the decoder part to a Massoth eMotion L as it was bugging me, now I have all the Lights working as they should on the Light function button, But... control of the sound functions still needs the handset set in Serial mode , if set to parallel I get lights but no sound functions I was hoping they would be in parallel now, unless I have missed changing a CV on the eMotion L
Loco in general now runs and accelerates a lot smother as well, and with lights on now I can tell which way the Loco is about to move off in![]()
A wise choice, as I mentioned much earlier in this thread it is the same swap I did with my green 28001 - the new L decoder makes it run a whole lot better. You still won't get over the serial sound problem, as you still have a serial sound board that doesn't understand parallel commands, but it's not really a big deal - just means that there will be a couple of seconds of lag time between pressing a command key and the sound function actually operating, especially for the higfher numbered functions.
Both Stainz smoke generators turn off with F1 so running serial on the hand set I can live with , until I get a Loco with full sound in Parallel then I would probably pick up another hand set to make life easier, as it would be a false economy to change the sound board in this one just to get parallel control![]()
Not sure what you mean by this?
Each loco you put into a Navigator can have its' own settings, so you save this one with serial set..
Yep still running on MTS III so no navigator, I nearly bid on another LGB hand set last week but changed my mindif I am going to buy another hand set then I may as well save up and buy a Navigator, as I can still use it with the MTS III
Totally agree, whilst the LGB 3 is a little dated, matching it with the Navvy boost its functionality immensely. A really good budget solution.Glad to hear you've got MTSIII rather than MTSII, Sid - gives you much more flexibility..... my (very strong) recommendation would be to buy yourself a Navvy as soon as you can afford it - just go for a cable-tethered one at this stage, you can always add a wireless board to it later - and you just won't believe the difference from using the MTS handsets!
As Phil alluded to above, you can store individual configurations for each loco on the Navigator so you don't then have to worry about switching modes on the handset as you switch between locos, the Navvy remembers all the settings you need.
With my 28002 with a Massoth eMotion L, I found that setting the decoder to fast-pulse mode (CV 49, bit 3) didn't work with the 28002. The A1 output does indeed pulse based on the function key pressed, but at about 0.25s per toggle. Experimenting with manually toggling F1 reveals that the sound decoder doesn't read the toggles if they are less than at least 0.5s apart.But... control of the sound functions still needs the handset set in Serial mode , if set to parallel I get lights but no sound functions I was hoping they would be in parallel now, unless I have missed changing a CV on the eMotion L
