My winter project LGB Dampfschneeschleuder Xrot RhB
We used to use old jet engines mounted on a wheeled frame, pushed by a fuel tanker, ( needed a lot of fuel) to clear the snow and ice off the runways when I was in the RAF during harsh Berlin winters.
Just encounted a small problem. Need a small 90deg angle drive any help gratefully received
How small is 'small'?
Maybe 5 mm spindles not too bothered about lenghts
[/quote]
[/quote]
Sorry Phil - I think what I've got is too big! :)
[/quote]
[/quote]
What size is it???????????
[/quote]
[/quote]
Having re-read the post I think I might have got hold of the wrong end of the stick - the drive you are after, is it for going in motor or is it a 90 degree drill drive?
[/quote]
[/quote]
It is for a motor to turn the impellor.
Thanks anyway But Doug has sent a link which may solve the problem
The centre of the impellor now sits about in line with the top of the motor bogies so I thought about a right angle drive. However this makes the motor sit too high . So the solution seems to be UJ's to off set the drive:bleh:
All so considered an inlie 90 deg gearbox but that made the motor too high and also the price was quite high
What about a couple of gears that will also alter the speed if required!!!
Plastic are cheap , but weak. Metal ones seem expensive. The ratio is not a problem as I will control the motor through a chip. Thanks for the thought
steve parberry said:
Mecanno, Brass? Ebay
Had considered it but I am going with UJ's
Just remember the straighter the allignment the longer they last, and the less chance of failure. As much as they are flexiable they prefer to go straight.. thats why they invented the constant velocity joint instead...
But its still a great piece of engineering:thumbup:
Don't think you can get CVJ's in this scale:laugh:
Thanks Gordon. A bit late!
Tonights progress. Milled some ali, bored for bearings. Next got to make end cap to retain bearing in housing. Thats tomorrow
Ignor the screw holes that was a first attempt
Blowerbox mounted on thee chassis
The impellor is giving problems. Made the first one out of copper, bad mistake.!
So different approach required
