Yes. On my railway. Honest.Rob s said:Slight thread drift any body got any good tips for using one of these
on analogue
Gizzy said:Tip for you Rob;
don't use your TCL in the wet, and run it as fast as it'll go when in cleaning mode....
pugwash said:Yes. On my railway. Honest.Rob s said:Slight thread drift any body got any good tips for using one of these
on analogue
Rob s said:Gizzy said:Tip for you Rob;
Thanks Gizzy, tried it like that the other day 10amp through TE
WOW on full chat it flies round even with the top switch turned right down,
and what a racket
It don't stop to quick on full chat either and tends to run up sidings when not expected
Got my first ever real/crash damage, when it shot in to a siding unexpected and smacked a fieldbahn truck at full tilt.
Truck went about 12 feet in to a tux craft engine shed.
Whats the best glue to fix lgb kit![]()
It def makes a big diference but bounces a lot on R1&R2 curves, leaving Zebra stripes
How many passes do i risk taking on very tarnished track ???
Got 200m to clean
Apologies for bit of thread drift Phil, just got a bit carried away
Will start a new thread on this tom
(edit - spelling, bottle is nearly empty)
KeithT said:I find I get the best results with the cleaning wheels just below max speed and the loco moving at about half speed, the bouncing is minimal and the stripes are removed after about 4 passes. If they are stubborn ie if the track has been out of use for a while, I run the TCL in t'other direction.
Philbahn said:Rob snail mail seems good to me.
Like I said in the PM it's only a model not a matter of life & death
Think the motor only
